Question about Whirlpool Refrigerators
Hi I have an Australian model 6ED25DQXFB01 Whirlpool refrigerator, the motor runs often and is very noisy (loud drumming sound), mechanic suggested it was a fan motor and subsequently changed that over, however, it is still very noisy. The suggestion now is that I need a new compressor. Could that be what is causing the loud drumming noise?? Thanks in advance for your assistance. Tricia
    President:
  • 1,462 Answers
Could be you need a new compressor but also check the pipework is not vibrating - if so, a bit of careful bending usually does the trick
Posted on Sep 30, 2008
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
My refrigerator is making a weird sound almost like like a fan whirling loud sound
Good day,
It is not uncommon for the evaporator fan motor to become noisy. It's accessed by removing the rear panel in the freezer section. Replacing it is not difficult. Just ordinary hand tools will do.
The motor should be available at any decent sized appliance parts house.
Take your model number with you if you don't take the motor itself, and it is wise to replace the blade at the same time.
Oct 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Motor sound in frig is very loud
HI,
you can check first this suggestion.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Australian model 6ED25DQXFW00... motor runs too often
hi thanks for the question i would pull fridge from wall and clean the coils at the back try this clean coils very important thanks the appliance doc
Sep 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Noisy
This will be either the motor bearings or the main drum bearing.
To find out, you need to take the back off, remove the belt, and spin the drum and motor by hand, and see which one squeeks.
My bet is the drum bearing. Good if it is as it's cheaper than a motor.
Look online for replacement parts HERE
You need to check if it is the right part for your machine, and may be cheaper elswhere.
It is a job for a competent DIY'er or technician. If you are unsure, employ the services of a domestic repair technician.
Thank you for using Fixya!
Jul 04, 2008 | Whirlpool AWM6100 Front Load Washer
Noisy [like loud motor running] almost all the time--for about a week
when you state "it's the compressor running all the time", does this mean it hardly shuts off? if so need more freon
May 27, 2007 | KitchenAid KTRS22EM Top Freezer...
Refrigerators Logo
130 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
