Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Removing front screen.
Hi, I have taken all the screws out from the front frame of the TV. I am having trouble removing the frame to get my screen out so I can acsess my lcd panel. From the inside the does not seem to be anything holding it in. It looks like it should slide up or out. Is there some clips I can't see? If the front does not come off, how do you get to the lcd panel(for dusting).
  • shawnya Oct 02, 2008
    As I stated aove...I have a MIT's, WD-52527. I want to remove the front of the tv to get to the LCD Panel for dusting purposes. I can not remove the screen from the back of the TV. I have taken all the screw out of the front frame to remove the screen, however I don't know how to take the frame or screen off. This is my question. How do you remove the front frame and remove the screen?
  • 927 Answers
Good Day;
You say you want to find LCD panel? On a WD- 52525 MIT's. Why do you want remove panel? What Brand & model do you have??
Posted on Oct 01, 2008
My screen was damaged and I finally found a new screen for it. How do I get the molding off so I can replace the screen?
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Sep 26, 2010 | Pioneer PRO-710HD 64" Rear Projection...
How to remove front screen
The screen comes off from the front. First take off the speaker grill and you can access the frame screws they are right below the screen. This only takes off the frame with the filter. After the screws are out swing the bottom out a bit and lift straight up on the frame then pull it out away from the set. I have found these to be very stubborn somtimes, but you should be able to get the frame to move then work it up and off. I hope this helps you. let me know if you have any more quesitons.
Apr 28, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
I want to take the screen off but i cant get the back off
Unplug TV, let it set unpluged for maybe a half hour or more (Just for safety) Pop off the speaker covers in the front of your TV, then remove the four screws under each cover, this will will remove the bottem face plate between the two speaker covers, then under that you find (I think four) more screws to remove just under the screen. Now if it is a BIG screen find someone to help you slide the screen up about two inches so that it will be released from the hooks on the inside. The screen is not at all heavy ( less than 5-10 Lb's) just flimsy and aqward. The screen is just a plastic frame holding two very thin plastic screens, one is a magnifing glass the other is vertical lines. If you must remove these from the frame,then as you remove the screen frame from the TV lay it face down and then remove the screws from the inside of the frame, Pay close attention to the way they come out if you put either one of them in backwards it will distort your picture and you will have to do the whole thing over again. The whole thing should only need a philips screwdriver and a half hour of time. GOOD LUCK.
Dec 27, 2008 | Toshiba 57H81 57" Rear Projection...
How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Apr 13, 2008 | Televison & Video
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Screen removal
1) Remove lower,front speaker grill
2) Remove screws along bottom edge of screen frame
3) Lift screen assembly off cabinet
4) Lay assembly face down
5) Remove just enough frame screws to get back in position--
    Don't force it----
6) Reassemble.........T.
Oct 28, 2007 | Toshiba TP55G90 55" Rear Projection...
Removing chassis for carry to repair shop
its called the light box and it secured by 4-6 screws from front and rear of the chassis frame assy./when you locate these screws that secure the frame it will pull out from the rear,caution don't break the front harness to the control panel assy. pull off the front and you will see how the chassis is supported to the tv frame and also remove the rear panel ,look at the metal frame as a box.
Sep 24, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Help me
you can remove the protector and the tv will work fine, they all come off a little differently however. I would start with removing the speaker grille and see if there are screws along the bottom of the screen frame. If so you can probably remove them and lift up un the entire frame it will be on hangers mounted on the sides. Once you get the frame off you will see how the screens are mounted inside with brackets. If not, some of the RCA's you would actually remove the wooden top of the TV and slide the screens out from the top. In this case you will see two things. 1) a couple of screws near the top of the TV on the sides possible hidden with a plastic screw cover. 2) on the back of the TV at the top you will see two metal tabs/slots that almost look like hinges. Remove the screws and lift the top from the front and it will pivit out of the tabs on the back. Then you have your screens exposed on the top and slide them out. Good luck!
May 11, 2007 | RCA P52921 52" Rear Projection Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
