Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm front loader-FE error code
Won't restart or unlock. Still has water in it. Is there a reset switch? I fixed the issue that set it off
  • Anonymous Oct 08, 2008
    FE error code and the water is still running. I had to shut the water off at the source.
  • Anonymous Jan 21, 2009
    I have the same problem whon't unlock
  • 4 Answers
The water overfills due to a faulty water valve. The valve needs to be replaced.
Posted on Oct 16, 2008
  • AmandaMarvin Feb 23, 2011
    How can I replace the valve? Is it a valve inside the machine? If so, can I just order the valve and replace it myself or do I need to get an LG repairman out here? Some additional details will help me fix my washer :) In the past, I've just turned off the power and restarted the machine, which worked fine. This time, no such luck :)
  • KIRSTEN Oct 12, 2011
    This just happened to me and I was able to get the door to unlock. Then I removed about half of the clothing and restarted the wash machine. It is working perfectly:)
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
On my LG tromm washer has an error code FE, what is the solution to this problem or how do i get it fix???
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 21, 2015 | LG Washing Machines
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Good morning, we have a LG Tromm front loader that started giving us some problems last night. It seems as it will not shut off, the water is continually filling in the machine, and it keeps draining. ...
"FE" means (no surprise here) "Overflow error. The water is automatically pumped out because there has been an overflow.
Since this condition clearly demonstrates that the water level sensor is working fine and doing its job, the very likely culprit is the water inlet valve. You may be locky and find that of you take the valve out, there is an ovstruction in it (sometimes a bit of grit gets trapped in the valve holding it open. More likely, the valve is failing and not shutting once it has opened. You may then need to replace it.
Jul 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,821 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
