Print spool service is not Running
HI this is suresh kumar
I am facing a problem for print spool service is not running but when i go to services it's working i have already stop and start print spool service but the problem is same.
This has helped me many times, thank you!
Posted on Oct 28, 2008
  • Computers & ... Master
  • 787 Answers
What makes you think the print spooler is not working? Is it because you get a message saying that it is not working or is it because you cannot print?
If you can stop and start the print spooler that would indicate to me that the spooler is running and you have a different problem. It is probably a corrupt print job, to fix this do the following.
1) stop the spooler
2) go to My computer
3) select the C drive
4) select the windows folder
5) select the system32 folder
6) select the spool folder
7) select the printers folder
8) delete everything in the printers folder
9) restart the spooler
Posted on Oct 07, 2008
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
Tip
PRINT SPOOLER PROBLEM ON XP/VISTA
Resolution:
on May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printer spooler
Resolution:
Mar 13, 2011 | Canon Office Equipment & Supplies
Print spooler not running. Dont know whether its connected but ive just had live help from microsoft for sound problem
Hi!
Resolution:
Feb 16, 2011 | Lexmark X1190 All-In-One InkJet Printer
I am facing printer spooling service not running problem even meny time I restar service auto close.
I had similar experience with the print spooling service crashing everytime I restarted. I discovered there was a pending print job in bullzip pdf printer that refuses to delete. So I uninstalled the pdf printer and restarted the pc. Kindly do the following:
1) Go to your printers and faxes and Check if there are pending jobs that have not yet printed out.
2) If there are pending print jobs, try to cancel them.
3) If they wont delete, try restarting the PC.
4) If after restarting the PC, the print job is still there, try uninstall the printer or delete the printer.
5) Re-install the printer.
Feb 09, 2011 | Computers & Internet
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
Print Sooler not installed
HI
Resolution:
Nov 08, 2008 | Dell Inkjet 720 Printer
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Hp psc 1200 series all-in-one
Right click my computer.
Click manage.
Computer management should open.
Click services.
On the right window there should be a list of services.
Find the print spooler in the list.
Check the status.
It should be default be started.
If not, then right click print services and select start.
Feb 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print spool error 1068
A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
click Start, then click run. Type in "services.msc" without the " " marks
Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
Oct 19, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
