Question about Refrigerators
Maytag MSD2454GR Freezer not freezing and fridge not getting cold... there is a click we hear then like 8 seconds of something happening maybe?? then another click... fridge is not cold, looking into the freezer I can see ice building up on the back panel. Last time this happened I had to buy a new circuit board ($150). Not sure why but the defrost heater must not be working.model # msd2456dew
  • 76 Answers
Im going to be honest with you,to me it sounds like 1 of 2 problems,
either you need a re gas on your fridge or you need a compressor.
Let a repair man take a look for you just to tell you what it is..
Sorry for this news.
Wouter.
Posted on Sep 30, 2008
Maytag MSD2454GR
You may need to recharge the condenser unit.
Jun 16, 2008 | Maytag MSD2454G Side by Side Refrigerator
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
This had never happened before maybe it is to do with the freezing weather but my bosch freezer will not go back to the temperature of 18 when I try to put it back to 18 it stays at 18 for a second and...
IN REPLY TO YOUR EMAIL THE FREEZER TEMPERATURE SLOWLY WENT BACK TO 18 DEGREE'S AND HAS STAYED THAT WAY AS IT SHOULD BE I CAN ONLY THINK IT HAD TO WITH THE FREEZING WEATHER AS OUR FRIDGES AND FREEZERS ARE IN A UTILITY ROOM AND CAN GET VERY COLD.
Regards
Patricia
Feb 02, 2009 | Bosch KGU34641 Bottom Freezer Refrigerator
Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
May 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
408 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
