Question about JVC Car Audio & Video
I bought a jvc KD-G140 and when i try to save my preset buttons they dont save after i turn it off
    Brigadier General:
  • 6,966 Answers
Your description indicates that the yellow wire is not correctly installed/connected. It should be tied to the always on B+12 such as the battery + terminal or the main wire of the ignition switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
How do i set clock on jvc kdg140
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob/button, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
May 11, 2010 | JVC KD-G140 Car CD Player
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
Apr 12, 2010 | JVC KD-G140 Car CD Player
Can't set clock i have a jvc kd-g140
hold sel for a few seconds then search threw using yer skip up and skip down button. untill u hit clock H then use yer volume botton to change.... then hi yer skip up again untill u hit clock M and use yer volume again. then hit sel to finish.
Nov 19, 2009 | JVC KD-G140 Car CD Player
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
My radio will not work
for turn off this radio press power botton for 3 second. if you press only with one touch is for mute. turn on press one secon---turn off press 3 second---1 touch is mute.
Sep 09, 2009 | JVC KD-G140 Car CD Player
Setting the time
PRESS THE 'SEL" BUTTON MORE THAN TWO SECONDS AND THEN WITH THE KNOB VOLUME CHANGE SET HOUR THEN PRESS THE FORWARD BUTTON TO SET THE MINUTES WITH THE KNOB VOLUME THEN PRESS SOURCE.
Mar 18, 2009 | JVC KD-G140 Car CD Player
Clock setting on jvc kd-g140 car audio deck
Press the Mode button (M) and the display will flash mode. Then hold the select button (SEL) until it changes to display something else. Hit left and right seek until you find clock M and clock H. Hit select again and use the volume button to change the time! Took me two freaking hours to figure that **** out.
Jan 11, 2009 | JVC KD-G140 Car CD Player
Don't know how to set the clock on my jvc kd-g240/kd-g140 car stereo
press and hold the sel button until the menu pops up then scroll through til you see clock settings.
Dec 20, 2008 | JVC KD-G140 Car CD Player
Car Audio & Video Logo
54 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
