No sound/test tone front front right channel
I have bought Denon DHT 1356XP system, which has a Denon AVR 1306 reciver just a week back. The front right channel is not producing any sound/test tone. I checked the connections, replaced the cable but did not succeed. Pls help.
Thanks
Swamy
India
  • Nagasimha Oct 01, 2008
    Thanks Marsover,
    yesterday i tried changing the speakers from right to left, the problem still remained on the speaker getting connected to the right channel. Later i pulled out the speaker wires from the reciver's end for the right channel, cut them and pulled out new strings from the insulation, twisted them and inserted, the speaker is working fine, though not 100% put closed to the left channel. I guess the problem was old stings in the wire which had got over twisted and were not parallel to each other.
    regards
    Swamy
  • 682 Answers
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Posted on Sep 30, 2008
  • mohamed eltoni
    mohamed eltoni Oct 01, 2008
    do not mention always at your service.
  • sameerbaig Dec 06, 2010
    Hi im having Denon 1306, all the speakers front ( L
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
Denon 785 reciever the subwoofer is producing no bass. Did tone check check all conections. Is it possible could be malfunction with reciver?
Is EVERYTHING in this scenario new (unknown functionality)?
You don't say what the result of the tone check was, nor do you identify the sub.
If your unnamed sub uses Line Level inputs just run one of the AVR's Tape Out's to it to prove the sub works. IT WILL BE LOUD since no volume control is in line with generic Line Outs. If it uses speaker level input, just run a speaker pair to it from the front channel. THEN you will know in which direction to proceed.
http://www.retrevo.com/support/Denon-AVR-785S-Receivers-manual/id/363dj796/t/2/
Jul 09, 2011 | Denon AVR-785 Receiver
Surround speakers are not working
Yes. Make sure your speakers are first properly connected, then enabled to operate on the setup menu. Then run either a test tone for all channels or media recorded in surround sound or run in 4 channel stereo to test.
Not all media will produce surround effects 100% of the time.
Jun 18, 2009 | Denon AVR-3300 Receiver
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Jun 20, 2008 | Denon AVR688
443 people viewed this question
 Grubhead
Grubhead
