I purchased a used computer and trying to add more memory but have not figured how to open the casement that the computer is housed- can you help?
    Brigadier General:
  • 6,966 Answers
Depending on the brand and model:
  • if it is a laptop, the memories would be inside/under a lid/panel cover normally held in place by a screw or two at the bottom of the unit;
  • if it were a desktop, then it would have locking screws at the back, a latch or a snap on lock.
Hope this be of initial help/idea. Pls post the brand and model, back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
There is an exhaust switch on the front of the unit. (open or closed position). When should each be used?
exhaust when you want to change air inside room more than you want cooling and dehumid efficiency. It ports air to outside, to be replaced by air from the outside (often from elsewhere in house, rather than via the AC unit). Does that answer it?
May 02, 2014 | Arctic King 10,000 BTU Slide Casement Air...
I formatted my 4gb sd memory card to my samsung gravity...when i try to transfer music from my itunes to my memory card(after attaching the sd card to my computer) the removable file page says that i need...
Hi sir =)
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte My Greetings
    Aug 17, 2010 | SanDisk 4GB microSD High Capacity Memory...
    I need to add memory module to my Dell desktop computer. I bought a 256MB Memory Module from Dell but it did not come with any instructions.
    ok. which model ram you purchased. For installation of ram there is no instructions. Open cpu and put the ram in empty ram slot. Put in right direction because if you try to put in wrong direction it wont set because that small cutting in ram is help to set proper way. try it otherwise call any technician for help.
    Jul 07, 2010 | Dell Computers & Internet
    I want to increase ram, what do I get
    First, you have to find out the max of ram that you can add to your pc. Then go to the website crucial.com and run a test where it will tell you what memory and how much you can add. If you decide to purchase the memory and after you recieved , open the case and locate the empty slop where the memory is going to be install. It should be the small slots not the white big ones. Then carefully open the case from the memory and then put i on the slot of the pc. Turn the pc on and then see if it recognize it
    May 24, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
    Interior dome/map light replacement - 2008 Honda C-RV
    You will have to pry off the lens CAREFULLY using a small screwdriver. There are two (or more) little plastic protrusions on each long side of the lens which fit into the casement. Look for very small slots along the side of the lens to insert the blade of the screwdriver. You can ease the casement away from the lens enough to get it to pop out. Re-inserting it is the same, but probably easier.
    Gently, give it a try.
    Hope this helps you.
    Nov 21, 2009 | 2009 Honda CR-V
    I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
    If you want to increase cpu speed so you need to increase RAM memory.
    You can fix it on motherbord of desktop cpu.
    But if you have low space on disk storage partition so you can add space to desktop with 2 method.
    (1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
    You can add harddisk as you like for example 80 GB or 160 Gb.
    (2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
    There is 2 type on
    RAM in currently.
    DDR1 and DDR2
    you can add RAM memory like 512 MB or 1GB or more.
    Aug 07, 2009 | Compaq Presario 5000 PC Desktop
    Need to add RAM
    Located here is the actual specifications of your W3052.
    http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3052
    The DDR means "double data rate", SDRAM is "synchronous dynamic random access memory" and DIMM is for "dual inline memory module". These are the way manufacturers describe the specific speed, type, and packaging of the memory. You need to get the correct combination for your computer in order for it to function properly. The PC2100 is NOT correct, at the very least it will slow your computer down, and possibly will not work at all. You should use PC2700.
    If you wish to add another 512MB taking your computer to 1GB total, then you only need 1 module, a 512MB, like the one that came in the computer. Do not purchase a 1GB module expecting it to work properly with the one already there. It probably won't. If you want to max out your computer's memory taking it to 2GB, then you will need to purchase 2 each 1GB modules, and remove the existing 512MB module.
    When you go to the computer store, you ask for either "one five-hundred-twelve megabyte, PC2700, DDR, SDRAM DIMM memory module" or "two one-gigabyte, PC2700, DDR, SDRAM DIMM memory modules".
    The part numbers from, Kingston, one of the major add-on memory makers are shown here:
    512MB = KVR333X64C25/512
    1GB = KVR333X64C25/1G
    Mar 28, 2009 | E-Machines eMachines Desktop PC
    Computers memory is up to 70%used
    Adding more memory is usually the cheapest, most effective way to speed up your machine. Ensure that your machine can handle more memory, then use a site like this to purchase the proper type of memory for your machine.
    Oct 29, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
    Casement Window Placement of Unit Meant for Double Hung Windows
    http://www.mrslim.com/Products/Category.asp?ProductCategoryID=24
    Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
    Jun 11, 2008 | Daewoo High Energy Efficiency Air...
    Ram upgrade
    Step 5: Remove a memory or continuity module Continuity modules do not contain memory, but are placeholders to close the memory circuit. Use the following steps to remove a memory or continuity module:
    1. Pull out, and then press down on the holding clips that retain the memory modules. The memory modules should rise up slightly out the socket. Figure 5: Opening memory module tabs c00571682.gif
    2. Pull out the memory or continuity module (for RIMMs) and place it in a static-safe container.
    Step 6: Add a memory module Use the following steps to insert a memory module into an empty socket:
    1. If RIMMs are being used, keep the following items in mind when purchasing and installing modules:
      • The memory configuration of channel A (the first two sockets) and channel B (the second two sockets) must be identical.
      • Continuity RIMMs must fill any open memory sockets.
      • When a continuity RIMM is required, it should be installed into the second socket.
    2. Align the memory module so the small notches on the lower edge line up with the raised marks in the socket. Figure 6: Memory module installation c00571683.gif 1 - DIMM (notches farther apart) 2 - RIMM (notches close together)
    Apr 11, 2008 | Computers & Internet
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
