Question about GPS
Nuvi 750 won't power on anymore
My nuvi 750 won't power on anymore.Won't even go into synchronizing mode
to show that it's charging.
I put the on off switch to lock. Then I prayed and held the switch in the on position for 20 to 30 seconds.
Presuming it might be a way of booting the system. Then I switched to off position. Waited couple sec
and tried powering on position in Wola!! it came on!!
Posted on Sep 30, 2008
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
Does`t seem to charge w/USB, in car after two hours only get 4 batteries is this normal?
Mine does the same thing, after years of freezing heating and thawing in the car the batteries just won't hold a charge anymore.Getting a replacement battery would cost about $24 plus shipping.
http://www.amazon.com/Garmin-Nuvi-750-Installation-010-00583-00/dp/B000UGPHI4
It is possible to change the battery yourself.
http://www.youtube.com/watch?v=qXXzsi9Ures
TickMagnet
Aug 15, 2011 | Garmin nuvi 1300 Car GPS Receiver
My hp 540 in battery mode while powered on switches off automatically within 4 second even before display appears, booting takes place whereas in adaptor it is reatsrting automatically
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 21, 2011 | Computers & Internet
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
Hi i have garmin nuvi 205w i was showing me ,accessory not suppor
maybe it is not charging
does the charging light come on?
both on the unit and on the car power plug.
does your cigarette lighter in the car power other things?
you can charge it with a mini-b usb cable connected to a computer.
Jan 14, 2010 | Garmin nuvi 750 GPS Receiver
Charger does not charge and battery is draining for Garmin Nuvi 750. What is the problem?
Check for power at the cord. Then check for power at the rectacle. If you have good power but it still doesn't charge, send to Garmin for repairs.
Dec 17, 2009 | Garmin nuvi 750 GPS Receiver
Garmin750 usb'd to PC. all i get is log with connect pic
When you connect the 750 to a computer it goes into data mode and the screen shows only the connected to PC icon. Let it charge for a few hours and then disconnect it from your computer and it will come up in Navigation mode,
May 17, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
GPS Logo
75 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
