Having problems getting my firefly hard drive to show in my computer.Device manager show the device but I can not get it to my files please help
  • 781 Answers
1. is the firefly working on other computers?
2. are you trying to use it in corporate computer? plugging usb devices may be restricted by a network administrator to protect corporate data.
3. is your usb adapter working. have you tried to plug another usb device to the same usb port?
4. how old is your system.? your system may be using usb 1.1 and your firefly may be using 2.0.. if that's the case you may have problems using your device in the that computer.
5. check your bios to make sure usb support is enabled in *********** board.
6, are you able to see your removable storage device (firefly) in My computer? if you do. what message do you get when double clicking in the icon to go into your device.
Posted on Sep 30, 2008
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
USB device does not recognised and pen drive doesn't show its symbol. and my windows drivers are all of up dated. Help me please
There are a few possibilities for the problem you're having. Some you can resolve yourself, some you will need further assistance from a professional.
It sounds like you've done some basic diagnostics already so don't worry if these steps start off with things you've already done.
First, with the kingston drive connected, open my computer and see if the drive shows up at all, if it does click on it and see what messages come up. If you receive a message regarding hardware failure the device is likely damaged, if you receive a message telling you the device is not formatted then you have do it yourself methods available to recover any files before you format the drive.
Second, open device manager and select the Kingston, if you're not sure how right-click on your Computer or My Computer icon and left-click Manage. Once the management console opens, left-click device manager on the left panel, then expand **** drives section and identify the Kingston, if it's not there the hardware has failed beyond do it yourself techniques. If it is double click the Kingston to open it's properties sheet. Select the Volumes tab and then click the populate button. If it shows up with approx 2GB then do it yourself methods will likely work, let me know and I'll point you to a specific article to walk you through the process, if it shows up with an absurd size or fails to detect a volume let me know and I will get you a referral into a nearby data recovery facility(please supply Country, State and City).
Either way we'll get your files if it's worthwhile. If the volume does show up in Device manager and your have no need to recover files from the device, you should be able to then select disk manager from the left panel, find the Kingston and format it to get it working again.
Hope this helps Fixya,
Chris
Dec 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I just transfer some very important files on my book essential drive.The first day it works fine but now it wont show the icon,but when i go to device manager,it shows as INITIO COMBO DEVICE CLASS. can...
jayvely
Sometimes the drivve letter that gets assigned to the drive will get bumped by another device. The links below will help you check Disk Management to see if you need to reassign the drive. Also if you did not get a proper disconnect from the computer you may want to try to connect the drive to another computer to see if it will detect.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 13, 2010 | Western Digital My Book Essential 1TB...
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
I have about 39gb of family pics and music saved on my freecom 250gb external hard drive and I have had to reboot my system with a backup file using ACER e-recovery management. since then my external hard...
In the control panel, go to administrative tools, open computer management. On the left side, there will be a "Disk Management" section, use that to assign a drive letter to your hard drive.
Sep 30, 2009 | Acer Aspire™ T180 PC Desktop
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
Help me please I beg you....All my important files are stored in a SimpleTech 120GB storage device and I cant retrieve it. It wont appear in the My computer but it is recognized by the device manager......
uninstall all usb drivers from device manager.
then clik on scan for hardware changes then it automatically install all usb drivers.
then check in my computer.Alkso try in other computer if you have.
Check usb cable is proper working.
Check in all usb ports.
Jul 15, 2009 | SimpleTech Pininfarina 80GB External USB...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
