Question about Sony Walkman NWZ-B105F MP3 Player
It can't be turned on!
When I press the power button, it will only be on for a second and then turned off.
  • 13 more comments
  • mkh mkh Oct 16, 2008
    i neeed help
  • guillaume_jo Oct 30, 2008
    Same problem. Battery indicates full when plugged on a computer, but it is turning off by itself after 1 second. I had it for a year now and it never happen before.
  • hosonto Oct 31, 2008
    i have the same problem... it cant be turned on... its just stay for 1 second then it goes off...!! please help
  • hnsh Nov 15, 2008
    It will only turn on a few seconds and turn off a moment later.
    I have reset the mp3 once. How does it affect?
  • saintcyr44 Nov 24, 2008
    I have the same problem with my walkman NWZ-B105F.It will only turn on a few seconds and turn off a moment later.
  • chaitra0318 Nov 29, 2008
    my sony mp3 nwd b105f when switches on for a second and then goes off..please help
  • jhoxef Jan 02, 2009
    Product: Sony Walkman NWD-B105F
    i tried all to fix my mp3, by resetting, formatting... but still cant turn on!
  • Anonymous Jan 20, 2009
    when I plug it in I get nothing-
  • biliy Jan 20, 2009
    when I plug in my sony it stays black, nothing
  • Anonymous Mar 12, 2009
    I charge my MP3 and it sais it is fully charged, but when I turned it on, it turned off right away. What am I suppose to do?
    My MP3 was fully charged and then when I turn it on it turns off right away. What should I do?
  • Anonymous Mar 22, 2009
    it can't be turned on! Does not delite files or format. Indicates full disk with not much data on it.
  • lea k Apr 03, 2009
    i tried everything... it won't read when i plug it in the usb slot... or if it does it has to be after numerous patient tries... and if it turns on, it randomly turns off... i try again and reset it... still wont load...it just freezes.... please help... i took great care of it, and i'm sure it's fixable somehow....
  • Anonymous Apr 03, 2009
    When I try to turn it on he gave me a message "boot error"
  • roaming hero Apr 17, 2009
    it cant be turned on]
I had to install the 1.1 firmware update, but that alone didn't work. I also had to format the device (it's a checkbox when you run the update utility.)
http://esupport.sony.com/CA/perl/swu-download.pl?region_id=3&Change_Template=1&upd_id=3265&mdl=NWZB105F
Posted on Dec 18, 2008
On the back where you plug in the headphones there is a silver dial that clicks back and forth. If you read the cylinder that wraps around where the headphones plug in it says hold. Just click the cylinder to the other position and that should do it.
Posted on May 11, 2009
  • 3 Answers
I just ran into this problem. You need to download the firmware update version 1.1 and load it. That did the trick for me. I'm not sure why I had the problem. My player was working fine -- although it probably ran out of juice and I needed to recharge it. Once I charged it, it wouldn't work. Once I loaded the new firmware -- it worked fine.
Posted on Nov 30, 2008
My sony mp3 player comes on says a name of a song no sound then says hold then the power goes off
Posted on Oct 17, 2008
My hp 6300 front panel lights are not working...how do i fix
Try below resets, one after the other if issue persits.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 30, 2011 | HP Officejet 6310 All-In-One InkJet...
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
On printer bling bling cannot do anything
Please try below resets one after the other if issue is not solved by 1st method.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Jan 12, 2011 | HP Officejet 5610 All-In-One InkJet...
Scanner Failure Cycle Power and try scanning again. Warming Up
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Jan 11, 2011 | HP 7210 OfficeJet All-In-One Printer
When I turn my hp g85 on,I get the following message:initializing,then a sound then press enter to allign cartridges then the printer flashes off &on and turned off by its self.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
  • Press and hold "Enter" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Oct 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
Oct 24, 2010 | HP Officejet 6310 All-In-One InkJet...
I hooked the printer up and all the lights are blinking it says reset power...what do i do...
Try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
Aug 19, 2010 | HP Officejet 6310 All-In-One InkJet...
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
May 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
May 02, 2010 | HP Photosmart 3210 Printer
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Sony Walkman NWZ-B105F MP3 Player Logo
902 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
