Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung rear projection tv
We have a 2 year old tv 46ish" rear projection, I couldn't see a model number, we have had the color wheel replaced a few months ago and now the tv just started to turn itself off in the evenings, usually after being on for a few hours. We have to wait a few seconds to minutes to get it to turn back on. Then sometimes it turns right off again.
Any clues?
  • Michelle Harrington
    Michelle Harrington Sep 30, 2008
    of course the warranty just expired!
    Sergeant:
    Champion:
  • 223 Answers
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Posted on Sep 30, 2008
I have a Samsung DLP, model hlp5063w. When I turn it on, the picture comes on and a few seconds it kicks off. After a few more seconds, it turns back on. It keeps turning on and off until I unplug it. Any...
2 most common causes of that sympton would be
1. Lamp failure is the most logical culprit BP96-01403a is the lamp number and I recommend only using an OEM replacement
2. Color wheel malfunction. Usually when the wheel fails you will hear a very loud motor spinning sound from within the tv.
If you havent replaced the bulb in a couple years that would be the most logical cause.
Oct 28, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a samsung rear projector tv model HLS4288WX/XAA
this sounds as if the color wheel is going out. the color wheel cost between 120.00 to 200.00 dollars online if you have the technical knolage you could change it yourself or a repair shop will do it I would guess around 300.00 but thats where I live
Jan 25, 2010 | Samsung HLS4266 TV
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
Have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
61" samsung DLP
The original lamp code number and color wheel part number must match...give me all the # ' s for research = Model # , lamp
numbers,color wheel numbers,etc.
Also, does it "melody" on and " melody" off ?? That is a function
of DMD module = might be defective...............T,
Dec 20, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung lcd tv
You have a defective color wheel. Its not easy to change. You must be familiar with the Lite engine. This TV carries 2 types of Color wheel. Look at the side of the TV for your version number to see which one it uses.
(1) Part number BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
(2) Part number BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
CircuitCity
Dec 07, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
