Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite front loading washer HE 3t
After running for about 5 minutes a code F5 appears in the window and the washer quits. Any suggestions?
  • 5,911 Answers
"F05" is a water temperature sensor error. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Make sure the connector is firmly attached to the NTC sensor upon your intial visual inspection. In many cases, the connector comes loose and causes the error. Make sure you follow the advice in the link provided for resistance readings. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Sep 30, 2008
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite 3t is banging in the spin cycle and the plastic ring behind the rubber boot is shredding. Any suggestions?
are you using a gel soap if not that may be your problem powder soaps cannot be used in front load machines it damagege the bearings in the back of the tub
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Error codes f and h
I have the HE 3t and an error code of f flashes at the 9 minute mark. Can any one help with this problem? When I contacted customer service that told me to unplug the machine and plug it back in. This did not solve the problem. Any suggestions?? Thanks, Paula
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 42922 HE 3t
sojds as if theresnot addeguate wate rsupply going to unit make sure
both hot and cold water is supplied and working to the unit
Apr 02, 2008 | Kenmore 46462 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
116 people viewed this question
Sal De
fordexpert
Robert Rankin
