Question about Philips SA5125/37 MP3 Player
Problem with Gogear SA5125
I bought this player for someone else, two in fact, one worked, one didn't. The person sent it back to me and I have tried the volume + and everything I can. The screen just flashes on and off when connected and shows a picture of a computer and the devise but won't stop flashing. What else can I do???? I can't even turn the thing on to see if it works after trying the repair mode
  • Anonymous Sep 30, 2008
    dont work
    my go gear insert the usb and my computer dont detect
Delete everything on it to get rid of the problem
Posted on Oct 10, 2008
Whenever I turn on my Philips GoGear SA5125 - it
when an Mp3 goes off like that, is means that the Mp3 is corrupted with virus from an application you installed or a data inside the Mp3 player and and has caused it to have memory loss.
To restore the memory of the Mp3 back to normal, you need to flash the Mp3. Flashing restores back memories that where lost.
After flashing it, it will start working properly again.
Take care.
Apr 13, 2010 | Philips SA5125/37 MP3 Player
Gogear SA5125
www.philips.com/support
enter country
enter model #
click on model #
click on software & drivers
click on firmware upgrade - software
or, just open the Philips Device Manager and click on "Update"
Sep 05, 2008 | Philips SA5125/37 MP3 Player
Gogear 4G
The patch is worthless:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this method does not work, get the product replaced. I usually do not admit this, but I work for Ph-----. Some computers cannot handle certain models. For instance, I love the SA5125 - it works for me, but I was personally unable to get an SA4111 working for me, and I work for the company. If the method mentioned does not work, it is hopeless.
-Tha Mp3 Doctor
Jun 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Can you help me
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 03, 2008 | Philips SA5125/37 MP3 Player
Mps3 sa51xx
If you find that the GoGear will not load the firmware upgrade, then:
1) Backup all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the upgrade
Also, if the Philips Device Manager says that your device is already updated with the latest software, then go to: www. usasupport. philips. com,and enter in your model number, SA5125/37, on the next page select SA5125/37 (not "37B"), on the next page click on software and drives, and click on Firmware Upgrade Software - this will ensure that your player really has been given the most current firmware upgrade
-Tha Mp3 Doctor
Mar 24, 2008 | Philips SA5125/37 MP3 Player
Grrr
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 23, 2008 | Philips SA5125/37 MP3 Player
My GoGear is not working
Umm what i suggest is that u press the small reset button on the back of your mp3 player i had the same problem and i did that and it worked and i hope it works for u
Jan 11, 2008 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
