Question about Jl Audio 300/2 Car Audio Amplifier
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
I just bought a new JL 300.2 amp,
i noticed when it hit really low beats the low ohm light would flash. So i turned the bass from the head unit down. While i was driving I turned up the bass from the head unit and cranked up the volume and put a heavy bass song on. After 20 minutes of listening to it the amp sub shut off and the amp did too.
it would flash the green power light every 5 seconds.
i took it out of my car (04 volvo s40) and put it in my cousins 04 VW passat. it worked fine in there.
Now im wondering if its my alternator? i checked the battery when it was off and the voltage ran at about 12.5 which is okay too.
I dont know, someone please help it would be greatly appreciated
  • ironmike1298 Oct 31, 2008
    i have the same problem but im getting a flash maybe every ten seconds and no sound from the subwoofers?
  • Anonymous Mar 22, 2009
    I HAVE A JL AUDIO 300 IT POWERS ON BUT NO SOUND THE BASS AMP STILL WORKS FINE
  • 323 Answers
This is normally due to clipping of your sub. Try reducing your low pass frequency to half and volume gain on your amp to 1/2. Your amp circuitry is over-heating. It's not designed to run like that. Use minimal gain on your amp and use your head unit to increase your bass. Turn up your stereo 'til you begin to distortion from there adjust your gains to your listening volume.
Posted on Feb 10, 2009
  • Dalynn Turner Feb 10, 2009
    ironmike: The amp is going into protection basically.
    This is after excess play I'm gathering on ironmike issue.
    The amp is getting way too hot.
    You may have the subs bridged to too low of an ohm for your amp.
    If you run your amp at a 1 ohm load eventually a 2 ohm stable amp will shut off repeatedly after say 10 seconds, because the amp isn't designed for a 1 ohm load.
    I would try running your amp in stereo with the subs in parallel.
    + to +, - to - on amp. Dual Voice + to + to +, - to - to - inside box.
    The JL 300 is designed to run at 1.5 ohms.
    This wiring is 2 ohm stable.
  • 631 Answers
Are you sure you don't have any shorted wiring or defective speakers?
Posted on Oct 01, 2008
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I recently got a JL 300 amp and at first the sub stopped working, then it came back on during the song I was playing. Later on it shut off all together. I don't know what the problem is..
Does it only happen on that channel. It is a 4 channel amp so make sure the other channels are working. It sounds like an RCA input prob. Try the sub on the other channel. if it works then it would be your RCA input needs resoldered.
Sep 04, 2011 | Jl Audio 300/4 Car Audio Amplifier
Have a JL audio slash 500 that isnt putting out any audio... i know the sub is fine. but i noticed the RCA inputs are loose and dont hold the cables very tight.. is this my problem and what can i do to...
Yes it possible that the inputs have been damaged on the circuit board of the amp. If the amp has hi level inputs you could try running a speaker wire input to it and see if it works. You might try another pair of rca cables to.
Aug 20, 2010 | Jl Audio Slash v2 500/1v2 Car Audio...
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL 300/V2 shuts down
you may have a weak power supply, check for proper ground ( clean contacts with a tight bolt to chassis), or too low speaker impedance because too many speakers or shorted speakers or leads to ground.
Apr 10, 2009 | Jl Audio 300/2 Car Audio Amplifier
Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 300/4 Car Audio Amplifier
Sub works but doesn't sound right
hey been there before u need new rca wires form ur radio to the amp.
Nov 12, 2008 | Jl Audio 12W3 Car Subwoofer
500/1 v2 and one kicker VS12L7
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Feb 03, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Sub JL 12w3 low sound
So I am assuming that you have just setup/wired this up recently? Have you had this working before?
You can have a look at the gain control on the amp & see if this have been set really low. This will help if the signal coming from your stereo is weak. The other thing I would suggest is to make sure that the amp can actually push this sub. I know what the specs say:
  • 1 channel audio amplifier
  • 1 x 350W RMS @ 1.0% THD
  • ThermalThrote full-on power assurance
  • 2 ohms stable (non-bridged mode only)
  • RCA type inputs
  • 0.3-6.0 VRMS input capability
  • Continuously variable High-Pass & Low Pass 50-250 Hz
  • Continuously variable Bass Boost settings (0 tp +12dB)
  • Frequency responce: 10-30,000 Hz
  • S/N >104 dBA at full power @ 0.1% THD
  • >80 dBA at 1W/1M
  • Remote gain control, mounting hardware & screws included
but I don't believe most of these. Many manufacturers embellish what their products can actually do! With the bigger more established brands such as JL Audio you will have no problems, their products have been tried & tested so much on the competition circuit.
Dec 15, 2007 | Jl Audio 12W3 Car Subwoofer
Jl Audio 300/2 Car Audio Amplifier Logo
689 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
