Question about Hamilton Beach Coffee Makers & Espresso Machines
3-in One beverage center coffee maker
Water is not pouring out, only 1/4 of a cup instead of a full cup.
A lot of steam and some drippings. I have used the vinegar solution as instructed in the book, but no results.
  • 3 Answers
Try clr (calc lime and rust remover) calc buildup causes that in most cases just rune water through it several times before use to rinse it
Posted on Oct 03, 2008
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Cuisinart DC 1150 (10 cup) coffee maker leaks out of the top.
I have experienced this same problem. You have to pour the water directly into the holding bay, avoiding the edges. I think water gets stuck around the rim, it just steams over the edge, or drips down the front and back onto the counter. I don't know why, but it happens, so just make sure you pour the water directly into the bay avoiding edges.
Nov 27, 2010 | Cuisinart DCC-1200 Coffee Maker
Very little water is dripping into the carafe
Try to run vinegar undiluted through the coffee maker first. If this does not help, you may have a plugged valve in the coffee maker or a tube/hole where the coffee maker water should drip through. if this coffee maker has a dispenser(where you put your cup against it and the coffee comes out) then there is likely a plugged up valve. This will require dismantling the coffee maker to clean it. Usually coffee makers get plugged up because coffee leaves a residue that requires scrubbing at time to remove.
May 26, 2010 | Dualit Expresso + Filter Espresso & Coffee...
If I put 6 cups of water in when it is done there is left only 4
The good news is there is nothing wrong with your coffee maker!
With any coffee maker that heats up the water, you're going to lose some of that water to the heating process (steam, etc.). You also don't get every bit of water out of the machine.
So that's why you need to look at the water reservoir level indications instead of using the graduations marked on the glass coffee carafe.
Typically, once you've figured out how you coffee maker works, I'd just "add" 2 more cups of water in the glass coffee carafe to get the amount of cups you want to brew.
I know my coffee maker is pretty close to exactly 2 cups shy of whatever I put in the glass carafe that I pour into my coffee maker. That's when I noticed the markings inside the water reservoir that didn't match the coffee pot. It was always 2 cups shy, so I just put 8 cups of water (using the carafe) to get 6 cups in the morning.
So I suggest you just you make these small adjustments to your water measuring and you'll get the right amount of brewed coffee out of your machine!
Hope you find this Very Helpful and best regards!
Sep 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
236 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
samber4
Level 1 Expert
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
