Question about SanDisk Sansa Clip MP3 Player
SanDisk will not turn on
It has been working fine, now it won't turn on at all. It won't come on when I plug it up to charge either... I'm very upset
  • Doby Sep 30, 2008
  • Anonymous Nov 27, 2008
    My sandisk Mp3 player won't turn on any more. It turns on when I charge it on my computer, but when I take the Mp3 off the charger it cuts of and won't cut back on.
Surprisingly the solution was quite simple after I stopped panicking. The Sansa Updater Setup Maintenance Program, I don't know where I got it from, probably off the web site for Sansa. I clicked it, followed themessage to delete current files and update new material. It told me to plug in my "dead" Sansa Clip (which was full of audio books I did not want to loose) and like magic it came to life. I sure hope this information helps someone. I have the silver 4g SanDisk and LOVE it
Posted on Sep 30, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
Wondering how long it takes to charge the Sansa Clip MP3?
I have had the same problem. It seems the radio never turns off and keeps drawing power. Solution: before charging, go to a song, start it playing, then pause it, then turn off the sanza clip. Plug it in and it should charge up fine.
Mar 22, 2009 | SanDisk Sansa Clip MP3 Player
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Won't start--No Sandisk display.
Download and install the firmware updater.
If that doesn't resolve, your player may really have a hardware issue. The battery is not replaceable by the consumer. My reccomendation is to exchange it with the store. If that fails, redeem your warranty through Sandisk (hope you saved your receipt).
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa MP3 Player
Was fine now dead
Hello jessisme,
What you describe sounds like either a battery problem or a hardware failure. I would recommend trying to charge the unit following the normal charging procedure listed in the manual.
If the unit will not turn on at all after charging then most likely the battery has failed or the or unit has some other hardware problem that will require service. If this is the case, I'd recommend contacting the manufacturer via their website at http://www.sandisk.com/techsupport for additional support.
Best regards,
Ken
Go Ahead. Use Us.
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Player will not turn on
I had the same exact problem too. Hold the botton down for at least thirty seconds. After press the botton as if you were turning it on. If it does it worl try it a couple of times. That's to me too and I was upset. I hope this helps.
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa E260's screen is white and it won't turn off
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
199 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
