Colors off. blue and yellow not lined up - Televison & Video
BLUE AND YELLOW LINE ACROSS THE TOP OF MY SCREEN COVERS ABOUT 25% REST OF PICTURE IS PERFECT HCN436W 43in RPTV PLS PLS CAN YOU HELP
Posted on May 20, 2010
Try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Posted on Sep 30, 2008
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: color is off, bue will not line up,yellow and
OK, I know this set very well--if convergence in the customer menu is skewed and red or blue will not adjust in some direction, you have a convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay for about 20 dollars if you can do it yourself or know someone who can do it for you--you can save the set and a lot of money......most shops get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
Posted on Nov 24, 2009
Color wheel for ws55313
Model indicated here DOES NOT HAVE A COLOR WHEEL- so you might want to enter customer menu and call up CONVERGENCE-THEN advanced convergence---a grid of yellow lines should appear----are they showing blue or red skewed etc?
Other is to look with color off to see if black and white screen or not?
Jun 14, 2012 | Mitsubishi WS-55313 55" Rear Projection...
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
Jan 03, 2012 | JVC AV-48WP30 48" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red color not lined up
You can try making adjustments to the convergence in the user menu. If they still will not line up you will need to have the convergence ICs replaces along with a few resistors in the convergence circuit. Fairly common in many rear projection TVs.
Sep 11, 2008 | Hitachi 57F500 57" Rear Projection...
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
310 people viewed this question
Top Televison & Video Experts
Electro Med Services...
