I have a amilo L7300 laptop. It is so slow and i would like to set it back to factory settings. how do I do this? Plus will I have to reinstall XP again. The laptop did originally come with it. Thanx
  • braleymartin Sep 30, 2008
    I have the same problem but my laptop didn't come with a recovery disk. I do already have norton antivirus 360 installed on it but it still incredibly slow. irritatingly slow
  • 781 Answers
According to this datasheet you have a recovery cd included
http://www.aocn.eu/FSCInfo/dox/1337056781.pdf
if you want to setup your computer to factory settings yes.. more than likely by using the recovery cd that should've come with your system you will be reinstalling the operating sytem and the software that came with your pc when you first bought it.
if you have decided to use the recovery cd... (the fastest road)
1. back up your precious data (used a cd, or a flass/thumb drive and put your music, documents, pictures and movies on it)
2. insert your recovery cd in the cd drive and restart the sytem
3 follow the prompts... everything will be deleted and your operating system will be reinstalled.
if you're reluctant to use the recovery cd (the longest road)
1.get and update a good antivirus (avg or avast are free and pretty good)
2. get and update anti-malware software (spybot s&d, adware SE, a-squared)
3. run anti-malware software* (you may have to run the program and scan your system several times)
4. run your antivirus sotware* (do it a couple of times to make sure threats are removed)
5. one you know there's no spyware and no viruses you may want to clean your registry (ccleaner is recommended)
6. defrag your hard drive.
* you may want to run these programs in safe mode (to enter safemode restart your system and after your pc finish the POST process press f8 (if you see the windows xp logo you missed your chance, restart and try again by having your finger on the f8 ready to start pressing) if you did at the right time you will see a black screen titled advance startup options, with the arrow keys select safe mode and press enter.)
sometimes depending how bad your system is even after completing 1-6 you may not get the expected results and if not done with care as you may run into other problems you may end up messing up your system causing you to have to reinstall the system using the recovery cd.
either route you take.. backup your data first
(I didn't mean that to rhyme but it did)
Posted on Sep 30, 2008
  • Francisco Cortes
    Francisco Cortes Sep 30, 2008
    braleymartin
    if you have xp installed on your laptop and if you don't have a recovery disk check if you have a hidden partition (some new laptops from compaq/hp for example will have a hidden partition that acts as the recovery cd) you can use that recovery partition to reinstall your operating system and leave it the way you got it when you first purchased it (check at start up for instructions to press an f key to go into setup or recovery). other systems will have a mechanism for you, yourself to create recovery disks, if you want post the brand and model that you have for laptop and we'll look up instructions if avaliable.
    in case you just simply don't have a recovery disk or no hidden partition to reinstall the os from. you may have to get yourself a cd with a copy of xp (you have to pay for it or risk to download a bootleg copy of internet) or as
    Saigua said you may want to think about getting a distro (version) of os: linux (which is free) and install it (if you're not familiar how to install linux you may want to read about it first, it's not complicated but it's a little bit different from a fresh install of xp.)
    saigua brings a good point of something cpus do when starting to overheat if supported by the motherboard and the cpu itself which is throttling (the cpu slowing down to protect itself)... so if you have an old system try to find out the service manual (post system details and we'll try to find it for you if possible as not all of them are avaliable) and follow the instructions on how to disasable your laptop to clean it up with a can of compressed air particularly the fan's as saigua said.. if you're not that technical and if you're willing to even sacrifice your laptop for your own knowledge i would say go for it and do it yourself.. if not (and you want someone to blame if something goes wrong).. you may want to leave the laptop disasambling for a techinitian of your trust.
    President:
  • 2,291 Answers
Uninstall the unwanted software , download reginout it will clean up ur pc to speed up to some extent
Posted on Aug 24, 2010
  • 981 Answers
Get a Linux or bsd or other OS distribution (the version appropriate to your laptop's CPU) on appropriate media (CD, DVD+RAM if your laptop reads those, flash drive, whatever you like) and a replacement hard drive (the interface (at least) has to match; and try 7300RPM ones for faster access) for the laptop. Then you can install the new OS on the new hard drive, optimize from there, and see if you're satisfied with the speed and usability.
It is possible of course that your CPU is throttling back if the heatsink fan failed...in that case you get to clean or replace the fan; that is, if you get a notion dusting might help when you are putting in the HD, get some canned air and carefully dust it.
Also; save for a new faster machine.
Factory reset
If it was by Asus you could. Not sure about Samsung. Usually laptops have a seperate partition then contains the files to reinstall from scratch.
Jan 01, 2014 | Samsung N145-JP01US Netbook
Fujitsu siemens amilo l7300 wireless problem
What OS is it using? Does it open webpages with a Ethernet Cable attached? Have you done ALL the Windows and Fujitsu Updates? Open Network and Sharing, what does it say? Connected to internet or Local only?
Feb 28, 2013 | Computers & Internet
My son deleted windows vista from his laptop and installed linux, if I delete this and restore factory settings will he get vista back
Your best bet is to contact Fujitsu and order a set of "Recovery Discs". If he installed Linux, chances are the Restore Partition (which allows you to bring it back to Factory Defaults) is no longer accessible in any way. Recovery Discs will allow you to reinstall Vista and the necessary drivers.
Aug 26, 2011 | Fujitsu AMILO PC Laptops
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced...
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Aug 02, 2011 | Fujitsu AMILO PC Laptops
Je veux telecharger gratuitement le pilote de carte son de siemens amilo L7300
Bonjour ,
Afin que vous voulez telecharger driver carte son gratuit pour Siemens AMILO L7300 voici le lien http://ts.fujitsu.com/support/downloads.html
ERNZ
Jan 31, 2010 | Fujitsu Siemens Computers & Internet
Keyboard is not functioning
go to control panel then system then device manager look for you keyboard uninstall it then scan for hardware changes the machine sould detect the keybaord and install it automaticly
Oct 12, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Fujitsu Siemens Amilo Li 2727 how do i take it back to factory settings
Hi there.
To factory restore a Amilo 2727, restart the laptop and press F8 as it starts up. It will bring you to a sub menu with safe mode etc, in that list you will see factory restore, choose that option and just follow the on-screen instructions.
Good luck with the restore and thanks for choosing FixYa!!
Jun 04, 2009 | Fujitsu Siemens Computers & Internet
Restore factory settings
Id try this option 1st :
Computer Cleaning Information
We did not find any results for Fujitsu > AMILO D-8820 PC Notebook need factory setting down load or cd. Other searches you may want to try: One of theses site will have a down load for your computer factory setting or also could find a cd factory settings for your computer.
Fujitsu Amilo Pro V2060
Fujitsu Amilo L6820
Fujitsu Amilo Pro V3405
Fujitsu Cd Drive
Good Luck, Please dont for get to Vote.
Dec 18, 2007 | Fujitsu AMILO D-8820 Notebook
Computers & Internet Logo
1,550 people viewed this question
David Payne
David Payne
