Question about Onkyo HT-SR800 System
Hooking up Wii System to HT-SR800
I have the cable system and dvd hooked through HDMI and they work fine. I added a Wii console and following the instructions per Onkyo, attaching the system via the auxillary jacks in the front of the amplifier. I've selected AUX on the amplifier but am getting no video or sound. I can hook the Wii directly to the TV and get both video and sound so I know the Wii is working. Do I need to configure the Auxilary channel on the Onkyo? Do I need an additional connection from the Onkyo to the TV or is the HDMI out cable enough? If I need an additional connection from the Onkyo to the TV, which jacks should I use?
Thanks
guide2u
  • 461 Answers
SOURCE: TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Posted on Sep 17, 2007
SOURCE: Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Posted on Jan 03, 2008
SOURCE: Tivo HD will not record when Onkyo HT-SR800 is off
Bypassing the A/V justs adds another remote. The A/V is designed to control all the inputs. Tivo sent a new box, but it made no difference. It looks like I'm going to switch out all the HDMI for component cables.
Posted on Mar 04, 2008
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
Posted on Jan 04, 2009
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Sep 17, 2007 | Onkyo HT-SR800 System
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Video disappears within 30 seconds
Hi Mark
I am going to take a stab in the dark here...
Did you plug the hdmi from the receiver to hdmi via the monitor hdmi output? this is needed so when you change the device on the receiver ie. between setop box and dvd the monitor changes with it accordingly.
You may also need to go to the setop box to set it to use hdmi output at the right frequencies too..ie. 720p 1080i or 1080p.Also set it so it only sends the picture via hdmi but audio still with optical out.
good luck
smeags
Jan 08, 2008 | Onkyo HT-SR800 System
Hooking up a console
well i would run it throw direct to tv ok then digital out from tv back down to this digital inn ok of samsung use hdmi to hd tv fro xbod 20 tims better looking
Dec 29, 2007 | Samsung HT-X50 System
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
Onkyo HT-SR800 System Logo
155 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
