Question about KDS 17S 17" Monitor
KDS Silver 17 inch monitor
I was not the person using the monitor when it failed by just going to black. I own the computer, it was used by another person when it failed. I'm a retired,
engineer,but know nothing about LCD monitors. When I first used it there was was a color test pattern when it was turned on.
Joe
  • Anonymous Nov 07, 2008
    The screen comes on and goes out in 2 seconds and stays black.
    Problem Solver:
  • 6 Answers
Several of these monitors I have repaired from green light "blinking" and also no light / black screen.
In many cases I found bad filter Caps after the switching regulator. The ratings seem insufficient to handle the convection cooling. I replaced C215, C209, C223, and C211 which are 25V 105C 470uF which are the primary filter for the switching regulator output I used , and I replaced C219 as well. When I replaced them I actually used a better rated 950uf capacitor laid on its side for space, since the C215, and C209 are in parallel as well as C209 and C223. All of these capacitors in both monitors were domed on inspection.
Posted on Dec 27, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
Am not sure what happened but I lost you in the Chat/Live Session. For a while I saw you typing a message ... and then it would appear that for some reason, the session was ended.
With your indulgence, I would post the additional steps:
  • If the LCD is receiving power, then probable faults could be the main board that processes the video and controls, the CCF (cold cathode lamps and/or inverter. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional;
  • If you are considering a DIY, the unit has to be opened up and the fault determined. In most cases, it is the inverter. This could actually be verified by running the LCD monitor and let the PC boot even if not visible. You could try shining a lflashlight at an angle on the display and see if there is a semblance of your desktop except that it would be very dark. If yes then it is possibly the CCF lamps or most likely the inverter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
Monitor comes on for an instant, then immediately goes black, any suggestions?
Yes, look for bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA702b_s/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 21, 2010 | ViewSonic VA702 (Silver, Black) 17 inch...
Hi, my BenQ FP72G 17 inch LCD Monitor keeps auto-adjusting every 5 seconds and every now and then it will turn itself off and later go on again. Any help ?
Make sure the cables are in well with a good amount of slack, it can cause a problem if your power cable or computer to monitor cable is loose
Jun 30, 2010 | BenQ FP72G (Black, Silver) 17 inch LCD...
AL1715 (Black, Silver) 17" LCD Monitor: my problem is not computer i am computer problem i...
The problem with PC or the monitor?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
IS THERE A PLACE TO HOOK UP SPEAKER TO KDS XF 7B MONITOR
This monitor doesn't have built-in speakers. You'll have to hook up separate speakers to the audio output jack on your computer with this one.
Feb 26, 2009 | KDS Visual Sensations 7b (Black) 17 in.CRT...
Aoc 17 inch silver black monitor problem
main regulator capacitor for the hot side of the power supply may need replacement, usually value is 220uf to 400uf 400 volts..
Apr 27, 2008 | AOC CT720G 17" CRT Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
2 inch black on both sides of the monitor (Horizontal)
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
KDS 17S 17" Monitor Logo
225 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
