Question about Hitachi DZ-MV550 DVD Camcorder
Bought the cam used need to know how to load the dvd looks like it might be ,missing a cartridge or something
Don't know much about these cams. it looks like it should have a cartridge to install the dvd with. if so how do i get one
The DVD-RAM media for this camcorder is encased in a plastic cartridge. Several companies make the media for this corder, Maxell calls it DVD-RAM Camcorder (DVD RAM 4.7) 2.8GB. You must verify it shows compatibility with Hitachi Camcorders, as the Sony media does not use the cartridge but is the same ram disc, so you could easily buy the wrong type.
Posted on Dec 13, 2008
Car wont run for long.
You don't change any parts when a check light comes on
You use the codes you get & go to diagnostic manuals you
have to buy,to follow the proper testing procedure, for testing
a component in a system, your codes pointed you to.
I would say you have not gotten the crank or cams in the correct
place ,when installing the belt,you need instructions with the new
belt,or you watch You Tube video or buy a cam belt manual
Sep 25, 2012 | 2000 Ford Escort
This repair shop says this neon 2.0l needs a cam sensor, bought a new part and bolted it up, i still have the code 0344, misfire detected... also new plugs and wires. any alignment required for sensor? i...
  • P0344 means that the Camshaft Position Sensor is having intermittent disruption.
  • Check the connector real well and the wires for breaks, cracks, bulging wires etc.
  • I think that aftermarket sensors are worthless to be honest. I recommend OEM sensor only because aftermarkets often don't work. So if you bought a CAM sensor at your local parts store then I would take it back and order from Chrysler.
  • A chipped tooth on your CAM sensor can cause this code as well because the sensor reads rotation. A missing tooth of the CAM will give an in the rotation of the CAM.
  • So the first this I would do is check the crankshaft position sensor as a fault from there can effect the CAM sensor too.
  • The crankshaft position sensor is in the engine block behind the alternator / just above the oil filter. See diagram below. Clean it real well and check the wiring.
  • Also make sure you clear the codes after the repair of they will remain. A CAM light does not usually just go away after fixing the reason for that code.
  • Now check the wiring and connector to the CAM sensor reall well and repair as necessary. Now clear the codes and see where you stand. If that light comes back and it is the same code then get an OEM CAM sensor and clear the codes again.
  • If that light comes back again then you will need to pull the timing cover and inspect the CAM itself for missing test.
  • If you have any questions please feel free to ask.
  • If you are satisfied with my help then please do leave a comment so others know of my quality work.
  • Crankshaft location diagram.
  • Pull the connector and the mounting bolt[s] to remove.
  • Hope this helps.
Regards,Tony
Nov 01, 2011 | 2003 Dodge Neon
I have a 1966 mustang 3.3l. i just purchased a new engine & i can't get the harmonic balancer to fit right. it's scrubbing against the timing cover when its tightened down. it seems like there...
66 L6 200. Are the timing marks easy to see? I just did this last week on our 66 block. Just bring it to TDC on #1. Remove the pulley/dampner and the timing cover bolts. Remember to remove the front oil pan bolts to the timing cover.
I use an impact wrench on the cam bolt while holding the crank bolt so I don't slip out of TDC. You'll then have to remove the oil slinger. It just slips off the keyway on the crank snout. Carefully pry the cam sprocket to start wiggling it off the cam. Both the cam and crank sprockets are "keyed".
Get the new sprockets and chain aligned with their marks. Slip the crank sprocket on first until the cam sprocket needs mounted. Just remember to hold the crank, cam sprocket, and chain as an assembly when mounting. Once you get the cam sprocket started, start threading the bolt to hold it in place. Tap light a rubber mallet to seat it further on the end of cam.
I would then remove the cam bolt and coat it lightly with thread-loc and then thread it back in. You don't want it backing out later when your driving down the road. ( don't ask how I know). Remember to put the oil slinger back on.
Your Engine has an oil slinger.
Wayne
Jun 28, 2011 | 1966 Ford Mustang
I lost some files from my Ultra HD Flip Cam during the copy process to my laptop. I used a recovery software to retrieve the missing/deleted files off the Flip Cam without issue. I cannot play the...
file recovery softwares will find a lot of files, most of those files will not be recoverable though, they will have been overwritten and contain random content mostly, you can\t fix these files if they don\t play in vlc media player after being recovered.
the content has probably been overwritten, the files could be months old etc.
vlc can\t recognize the format because the files are corrupt. If a file is OK it will play back on vlc media player, if it does not play back its been corrupted beyond repair.
All you need is VLC and FFDSHOW, K lite pack has it, so you got all the decoders that you would need to play back a file.
frankly, you are just waisting your time if you don\t believe me.
Nov 28, 2010 | Cameras
Bottom agitator spins but the top piece is loose like something is missing. The top piece of the agitator and the soap despensor just come right of and spin freely... there is nothing holding it on. Looks...
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs on the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3094543 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My A4TECH PK-636MA WEB CAM WON'T WORK AFTER INSTALLATION
remove all previous web cam drivers from the pc ...
reinstall the driver ...and after you plug it ...let the wizard to search for the driver and do something that seam like reinstalling second time ...
if it will gave you some errors for missing files (example: missing dll.d50 or something like this ) just click browse and locate the file manually from the installation cd ...or from the folder where is installed it depends...sometimes I dont know why ...just do not see some files...maybe its something about compatibility ...or ...OS )
if after this is still not working ...see maybe is not a webcam that will work with your operating system ...some dont work on vista ...or windows 7 ...
Mar 19, 2009 | A4tech G-Cube Cosmo-tini notebook webcam
I lost my cd in stalling my web cam and now i want to know how will be
Hello kurdapia_kul...
to find Creative Labs drivers, go to this page: http://support.creative.com/and in the upper right hand corner, choose your region of the world...on the next page, choose your country and language. This is important as some models are only sold in certain countries, so be sure to select the country where you bought the cam.
once you are in the support page, click on the cams section and see if your cam appears on that page.... if not, and you need help to figure out what exactly to look for on the site (there is quite a lot) use the link to help you 'identify your cam' in the upper right corner above the photos of all the cams.
after that, use the link at the bottom to find your cam in the lists provided on the next page.... once you select something from the list, you have to click the 'next' button at the bottom.... that should take you to the page where you can download your driver, and possibly other software and a manual if you need those things too.
be sure you select the driver for your operating system, and keep in mind that some older cams don't work on newer systems, like windows vista.
let me know if you need more help on this :)
bru*
Feb 18, 2009 | Creative Labs WebCam Live!
The Internet drop off when using Video Call on Skype and MSN
UNPLUG THE CAM AND LOOK IN DEVICE MANAGER.FIND YOUR CAM AND UNINSTALL THE DRIVERS.REBOOT.DOWNLOAD NEW DRIVERS FROM WEBSITE FOR CAM.MAKING SURE ITS THE RIGHT MAKE AND MODEL AND ITS THE DRIVERS FOR YOUR OS.THEN REBOOT.PLUG CAMERA BACK IN.SYSTEM WILL DETECT IT AND LOAD THE DRIVERS.HOPE YOU MAY WANT TO FIRST TRY RESET UP ON SKYPE FOR CAM/MIC.
Nov 20, 2008 | Logitech Webcam
HITACHI DVD CAM DZ-MV208E PAL 240X
I use Maxell dvd-ram 2.8GB 60 mins double sided. works perfectly well 4 me. can purchased in Argos.
Bokhari
Aug 29, 2008 | Video Cameras
Finalizing discs
IT USUALLY NEEDS TO BE PLUGGED INTO THE MAINS ADAPTOR TO FINALISE DISCS TRY THAT.
Nov 08, 2007 | Hitachi DZ-GX3100A DVD Camcorder
Hitachi DZ-MV550 DVD Camcorder Logo
60 people viewed this question
Top Hitachi Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
