Question about Sub-Zero 632 / S
Sub Zero 632 leaking water
We have a sub zero 632 approx 7 years old. Over past few days has been leaking water out of the front right and left corner areas on to the floor. Leaking is spuratic. Seems to be increasing each day. Any ideas?
  • Anonymous Mar 29, 2014
    heating element
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Posted on Nov 24, 2008
  • jack williams Feb 10, 2011
    AFTER REPLACING GASKET ON DOOR STILL HAD WATER COMMING OUT OF BOTTOM OF DOOR BY HINGE THEN I SAW YOUR SOLUTION SURE ENOUGH IT WAS PLUGGED WITH A BROKEN PIECE OF PLASTIC THAT FIT PERFECTLY IN TROUGH I REMOVED IT AND MY WATER PROBLEM WAS SOLVED THANKS ,JACK
The water fill hose is out of place and is pouring water into the ice bucket instead of the ice tray. Unfortunately the solution requires that you disassemble the front of the icemaker. You can see the fill tube on the right if it is not in the proper position it may be repositioned. It may also need to be replaced if it is broken or deteriorated. Worked for me.
Posted on Oct 10, 2008
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Hi. My Sub Zero 632 is dripping water from the bottom corner of the freezer door. Can you tell me what the problem is and how I might fix this? Thank you so much.
It does appear that your side by side refrigerator has an ice maker, so that rules out any extra water from a faulty valve.
I think the seal on your freezer door may be broken/torn.
Usually there is no water (per se) in the freezer, but as things thaw, or as the door is opened it can create condensation that leaks. The freezer will retain cool for a while but eventually things will thaw out and water will leak.
Please check the thermostat for the freezer, and make sure there are no containers leaking in the fridge portion.
Good luck.
Sep 26, 2010 | Sub-Zero 632 / S
How can i find stainless steel panels for the front of my sub zero model 590
We are factory authorized Sub Zero parts and service. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST for all your Sub Zero parts and supplies.
We look forward to hearing from you. Thanks, Ella
Nov 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
I have a 7 year old sub zero 632. The
The sub zeros I have worked on have a compressor for each side. Is your fan blowing. You may have a defrost timer or heater. Possible low on gas but thats not very likely the sub zeros are made very well. Check to see if fan is blowing. Check condensor coils on top to see if they are clean. Check to see if your condensor fan is blowing. These are just possoble problem you can check if every thing looks good. Call a service tech ask for free estimate on repairs. Rus
Jul 06, 2009 | Sub-Zero 632 / S
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
I have the problem of the ice tray being covered with a layer of ice and very few cubes. I have a Sub Zero 632 ice maker that is 8.5 years old. Am I best off just replacing it or try to find out which part...
Try replacing the water filter if it has one, also it could be a bad door seal or may not be properly removing ice if it is a frost free model
Dec 16, 2008 | Sub-Zero 632 / S
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 632 / S Logo
893 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
