Question about Kenmore 62602 Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
Hi, I have a kenmore series 90 electric dryer model #11060912990. I replaced the heating element because the air was blowing and it was not hot. I first checked its continuity and it was bad. After changing I put it back together now not only is the air not hot it does not blow at all. I checked all the air flow areas for stoppage. Could someone help before I go out of my mind! Dan
  • 943 Answers
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My Sears Kenmore 90 Series takes too long to dry cloths
First you need to make sure that the lint trap is completely clean. I don't mean just taking the screen off and making sure there isn't lint on that. You need to take the cover off of the back of the dryer and remove the shute the lint screen slides into. That can be backed up and it's quite common. Also when that happens it tends to blow out the fuse that is located in the same general area. It's about an inch long, white, with two wires connected by plug on terminals. Make sure you unplug the dryer if you're going to check that. Remove the two wires and with an electrical tester check for continuity across the two terminals. If there isn't continuity you'll also need a new fuse, Hope that helps.
Mar 20, 2013 | Kenmore Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Mar 24, 2010 | Kenmore 73952 Gas Dryer
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
311 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
