1st I had poor A/C no heat. Replaced vacuum control for vent, located on passenger side by the glove box. A/C worked perfect but no heat. Replaced Heater / AC Door Actuator Motor and now I have heat but no A/C. All modes work (Floor/Def/Vent etc) Seems like the blend door is not opening for AC.Comp runs and cools.
Make sure the a/c clutch working and the line is cold , let me know .
you have problem Heater / AC Door Actuator Motor , make sure every thing OK there .
turn the switch a/c on cold , make sure the door cold open , put the AC Door Actuator Motor . your prob[em you have it backward .
I didn't think it was possible to put the actuator motor in backwards. I have a friend of mine who's a mechanic working on it.
AC Door Actuator Motor female fiat in door male wrong way . or bad switch hot cold .
aim sorry , you try do the best you can , you good , let me know after your a/c fix , i hop to hear from you .
The clutch is engaged and it is cold and sweating back to the compressor
