Question about Nokia 1100
Battery life reduced 80%
The standby battery life has dropped from 5 days to less than 1 day. Tried changing the battery with three known good ones and they all only last 1 day. Other than the shortened battery life, the phone works fine.
Thanks
  • timmymao Oct 16, 2008
    Thank you for the suggestion. I tried changing the battery with three other ones and none last longer than 1 day. In another phone, they will all last 3-5 days. Perhaps the phone itself is using too much power but I don't know why.
  • 31 Answers
Hi,the problem could be with the battery,change the battery.
hope this is helpfull
Posted on Oct 16, 2008
My cell phone battery dies much quickly
Some cell phone batteries work fine for a short period of time and then rapidly diminish their holding capacity. The battery that has previously worked fine for 10 days standby begins a downward time drop to last merely a couple of days. A simple procedure that I have found to be invaluable is to:
1. Turn the power to the phone off.
2. Remove the battery from the phone.
3. Replace the battery into the phone.
4. Fully charge the battery.
5. Test the results by noting the time and day of item 4 above. Leave the phone on standby and see if the charge will now last many days. If so, congratulations, your phone is almost as good as new, and you didn't need to find and buy a new battery (or bother the customer service staff).
Feb 05, 2012 | Sharp Cell Phones
probably your hooking up additional gadgets to your laptop or maximize the performance settings of your laptop and that translates to more power consumptions.
try reducing or use the recommended power saving settings on your unit or just maybe its time for your battery to say good bye because its about to end its service life...
Dec 29, 2010 | Compaq Computers & Internet
Short battery life when idle - Sanyo Xacti VPC-HD2000
Strange, mine lasts a very very very long time, but in a standby state (power on, just close the lcd lid). Have you tried to just keep it in the standby state? I will never turn it off unless I need to, like to change sd cards, because it is super quick to capture video and it does not kill the battery.
I have 2 of these dual cameras and John is quite right, the Sanyo HD2000 is not a "normal" camera, its quite abnormally exceptional and way ahead of its time! Having a f1.8 lens, 1/2.5" cmos, 1080p @ 60 FRAMES/second, really makes it not "Normal". You will need a better computer to process the crazy 1080p/60fps images.
Jan 14, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
Asus Eee PC Series 1000he Battery Life
You can try to completely discharge and recharge a few times to take it through its full cycle. However, you probably won't get much improvement. Batteries wear out with time and, after one year, I'd expect to see significant capacity loss on a machine such as this with typical usage patterns.
Aug 05, 2009 | ASUS P5PE-VM Motherboard
A968 battery problem
This is a very commen with Chinese stuff. The looks are perfect, but the quality is exactly otherwise. Sorry to hear of your prob. See if you can find a standard battery of a good brand with the same specifications. Its better to buy a good and expensive battery than go in for three low quality ones. Give it a thought.
Aug 05, 2009 | Cell Phones
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
Battery
maybe ther is a shortage on your cellular phone.
Mar 10, 2008 | Nokia 6233 Cellular Phone
Motorla Slvr L7 Won't hold charge
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Dec 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Nokia 1100 Logo
192 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
