Question about GPS
Just got the garmin nuvi 260w today and plug in car and will not power up?
  • Anonymous Mar 09, 2009
    We bought our gps and can not get it to turn on. We have pushed the rest button mulitple times and tried charging it for hours, and still nothing. I am returning it.
RE: Garmin Nuvi 260W Grrrrrr...I could not get my new GPS to turn on straight out of the box, even after charging it in my car for hours. I watched the on-line video - but could not find the reset button (different location than what was on the video). I finally thought I couldn't reck anything worse so pressed the tiny reset (sticker) - not button with my fingernail so hard I practically went through the sticker - and that worked.
Quick Start Manual should state SOMEWHERE that your unit might have to be reset before being able to be powered on. Clarify that it is a button hidden under the sticker in really small print. This was very frustrating.
BUT - Once I figured it out - it was so easy to work - I was impressed!
Posted on Sep 30, 2008
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
I have a new garmin 260w given to me about a year ago today when i plugged it in to my cigarete lighter it came on then quit charging does that mean my battery is bad and how do i check thanks
On the cigarette plug adapter there is a fuse on the tip of plug its silver or black..... its spring loaded so unscrew it carefully. Check and replace
Oct 12, 2010 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
My 2 yr old Garmin nuvi 200 was working fine...when I got home and turned the car off, it quit working and won't turn back on. I keep it plugged into the lighter, so it's not battery power.
No it's not the battery power: your nuvi has suffered the firmware equivalent of a stroke.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
I havew a Garmin nuvi. Yesterday I was driving
Check the fuse in the lighter end of the cord.....it may be blown and the unit is not getting power.
Oct 26, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
Updating my gps
go to mygarmin.com you can update one time for $69.00 or unlimited times for $129.00. You can also download a bunch of different vehicles for you GPS! Please rate my answer if youre happy!
Apr 23, 2009 | Garmin nuvi 260W GPS Receiver
Proper charging advice for Nuvi 260w
Turn it off and Always unplug it when you're done with it.
That's assuming you have a live plug (stays on when car turned off)
Mar 16, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
GPS Logo
155 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
