Unit beeps every other second. Green On Line light is only light showing on the front of the unit. No other lights are on. Sensitivity light on back of unit is green. APC recommended I do a "Brain Dead" which didn't fix the problem. Any insight into what is causing this problem and can I fix it myself. APC is recommending that I have it serviced or get a new one.
Beeps have vast causes, covered in the manual
AC inputs too low or high
lightning hits or breakers popped.
Line AC input surges.
UPS never setup right day1.
UPS overloaded
UPS battery tests fail.
try to load APP called powerchute, BE business edition and see what it shows>?
SUA750XLI is one fine UPS I have SMT750c here.
this great product has powerchute software and free.
to run and see log file and errors in pure English words.
learn to use powerchute.. and not work blind.
using read USB port to PC and UPS.
see error logs, etc.
last model is 2008
SUA750XLI ?? sticker rear shows this??????????????????????????????????????????????????
https://www.youtube.com/watch?v=NOQq9j2IL_8&t=10s
The flow chart for this UPS, (apc.com) "troubleshooting" ends with, needs service.
brain dead.
brain dead is for UPS that seem dead
but in truth are not.
what it does is reset all chips inside to they are not latched up from any surge events even minor lightning hits.
the SUA750XLI
on the rear sticker?
not running powerchute for BE business edition app?
not told is :
how old is UPS or its batteries? first?
batteries are 9 out 10 causes of failure.
even 3 years old they fail faster if deep discharged 300 times.
do the battery tests?
Smart-UPS750XL. Unit beeps every other second.
do the brain dead test at step 3>?
battery out. not connected
then push power button 3 to 5 times long push, 10 seconds each. (leds might twitch)
last and best is.
and let UPS set for 1 hour 100% dead
no bat no AC line in,
dead dead dead
this fully discharges all caps.!! goal 1
this sure can wake up a dead UPS if it suffered a power surge. event.
the battery back
AC back
and test the UPS fully.
what I do is test all batteries on a bench first with a test lamp.
https://www.pcdied.com/UPS/SMT-750/APC-S...
apc failure here (words)
is that some caps in any electronics system can take and hour or more to discharge, below 0.3vdc.
even a hail mary, over night check
no AC power cords at all end to end UPS
no batteries.
overnight, some do wake up. at 0.3vdc, alive again.
chips made most made have a latch up feature clamp'er, that protects its inputs from
surge damage, and recovers when all DC in the box goes below 0.3vdc.
then the protector unlatches.
SOURCE: APC Smart UPS 3000VA - Dead UPS
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
SOURCE: beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
SOURCE: Have brand new APC 900 UPS and when plugged in,
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
