Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSR model Washing machine
I just received a used washer from my sister and she wasn't sure if it worked or not. I hooked it up in my house, and started a load. It filled all the way up as if it was going to work fine... Then when it was time to start "agitating" or "spinning", nothing happened except for a loud buzzing noise and mabye a bubble or two coming from the bottom. Some guru's suggest a lid switch problem, but i took off the control panel and all of the wiring looked just fine..... Can you help me?
  • 5,911 Answers
The lid switch on your model is located by the left lid hinge under the cabinet. It is activated by a rod on the left lid hinge. If you open and close the lid, you should hear a clicking sound as the switch is activated. If you can't hear the switch, sometimes bending the rod on the lid hinge will correct most contact problems. I haven't seen many of these type lid switches go bad. Its almost always been a simple adjustment to correct a contact issue.
Now, if you are sure you switch is good, the loud hum sounds like you have a drive motor seized up. Try removing the motor to see if it will free spin. The following link explains how:
The motor comes out fairly easily if you follow the steps in the link provided. This will make the motor more accessible to you. If the motor will free spin, check the motor windings by taking resistance checks to be sure. There should be a wiring diagram located inside the operator console.
Your motor also has a motor start switch. If the motor and windings check good, you may have a defective start switch. I apologize for not having definite solutions here, but I'm trying to be as thorough as possible. Its often hard to determine a cause based on some symptoms, as there could be several possiblities.
If you go to and type in your model number, there's an excellent exploded view diagram of the drive components under the "Brake/Clutch/Gearcase/Motor and Pump" heading. The drive motor and switch are listed as items 19 and 20. The lid switch is located under the "Top and Cabinet Parts" heading as item number 11.
I hope some of this information is helpful to you. Let me know if I can be of further assistance to you.
Posted on Sep 30, 2008
I have a whirlpool duet washer/dryer. Large capacity i think. When I wash my husbands work clothes (dirt, grease, etc) I'm not sure if they are getting clean. They come out smelling just like they...
Could be the wash soap your using.You need to use high eff soap with this washer.
Tide makes a high eff soap,you will see it on the lable marked high eff.
Also check your drain line for any debris or blockage and remove.
Aug 01, 2011 | Whirlpool Washing Machines
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello, my name is Jorge, i live in Ecuador. what is the grade of oil for the LSR 8433KTO gearbox?
Appliance repair says 75-90 is good and makes sense, since in all practical application, it's like the diff. in a car or truck.Glad to help Jorge.
Aug 12, 2010 | Whirlpool LSR8433K Top Load Washer
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Have a whirlpool model.# LSR 8444LQ0 Balance problem anyone know what maybe the cause and a fix it for it?
Check your machine standing level. Adjust it with it's adjustable screw legs.
Check the set of springs or hydraulic shock obsorbers ( depending on mododels) that supends the water drum assembley set.
Check drive belt tension. during high speed spin might slip intermittently.
Finally your loading material!
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Whirring clik
sounds as if you have a bad motor coupling( this machines equivilent to a belt), i would try to search through you tube for a video as how to replace , easier to watch someone then try to explain it, its def there ive seen it and its not a real bad repair, parts probably $25, a servicer will get 150 to 200 to do it
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool LSR5132PQ Top Load Washer Logo
1,376 people viewed this question
Dan Webster
Dan Webster
Sal De
