Lift out the drainer by lifting upwards then pulling towards you. Pull the door from the left side and it will swing out. Pull out the brew group, if you want. Start cleaning.
If you push the power button and the machine will not turn on and it a
newer machine there is a reset button on the side of the boiler that
needs to be pushed. This will get you power again. If the machine is
older than 3 years there is a thermal fuse on the side of the boiler or a reset button on the back side that you can push but if that won't solve the problem you probably need a new board or power filter.
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
Hi Check your door switch. Back side of the door on top in the center is a pointer. That pointer pushes a metal bar inside the machine. If you can see the piece of metal(silver color) in the machine then you may have a thermostat that has a reset button you have to push inside the machine on the boiler.
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
The brew group is out of place. --> -->
The brew group cannot be taken out. --> -->
Turn on the machine and close the service door. The brew group will automatically go back into place.
Turn on the machine and close the service door. The brew group will automatically go back into place. The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
