Question about Dryers
Kenmore electric dryer model# 66702692 66702 runs but no heat
  • 943 Answers
Hi thanks for the question . first check the voltage. 240 volts / then remove back panel. look for burnt wires. check the element, and thermostats. now you need a meter for these test. you can buy a cheap volt meter at radio shack. real cheap. check those parts. have a problem. get back to me. thanks the appliance doc
Posted on Sep 30, 2008
  • 39 Answers
Hi soccerref209
This could be caused by a number of things. The first thing to check is that you have 240 v
, the dryer will run with 120v but the element need 240v to heat. It could be the element its self or a thermal fuse. hope this helps.
brent
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My kenmore dryer model 86873100 will not heat
gas or electric? if it runs, check the heating element for a break. make sure the dryer venting is cleaned or the safety on the heater element will shut off the heat to prevent a fire. you may also need a thermal cut out kit which is mounted on the heater assembly.
Oct 11, 2009 | Kenmore 62602 Electric Dryer
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Kenmore gas dryer model#73022 no heat when running
The first thing is to look at your tech manual and do a continuity test on the thermistor.
Oct 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs no heat
the kenmore is manufactured by Whirlpool. there are thermal overloads in the blower housing and one in back where the elements are. if these overloads open, 1) motor won't run 2) element won't turn on. check for an obvious open element.
Sep 13, 2007 | Kenmore 63942 Dryer
Dryers Logo
483 people viewed this question
Top Dryers Experts
