Back to:
Tags:
Casio Exilim EX-Z750 Digital Camera
EX-Z750 sat/contrast adjustments
By Duke - usenet poster
Is it possible to change the setting and contrast more permanently? For example, say i'm doing a whole day of outdoor shooting and set the saturation and contrast the way I like it (leaving everything else auto i guess), when I turn the camera off (to conserve battery) and then back on, will i need to go through and change these settings again?
I know there are 999 presets you can make ... is it possible to make a preset that's just like the normal auto mode, except -1sat -1sharpness -1con, everything else auto?
Basically can I make a preset that's just like the normal turn on, point and shoot auto mode, but with the saturation, sharpness, and contrast altered ever so slightly? Or do I need to specifiy non-auto settings for each of the variables in a preset mode?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2006
Not Rated (0)
man1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If I'm not mistaken the Z750 will remember the contrast, saturation, & sharpness adjustments even after power down. You can lower saturation to -1 and it will stay at that setting.
However, I believe if you use a BestShot Scene then it will use the preset setting. For example, if the Portrait Bestshot scene was set to Saturation +1 at the factory then that is what will be recalled.
It will not adjust the saturation to -1 (as you set in the default) or to 0.
Myself, it MIGHT be nice if the Casio could set it to 0 (+1 factory setup, adjusted by -1 for my own preference = 0 final setting). To me the default saturation is just far too high.
Once I get my replacement Z750 (1st one had defective lens), I will probably setup a few custom Bestshot scenes with the saturation adjusted accordingly
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on EX-Z750 sat/contrast adjustments:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
Hello, I bought this camera on ebay and the battery does...
I have casio Exilim EX-275. After I set the time, date and...
i've had the camera for 9 months (since christmas) and it...
After shooting the foto, the image stored is very white in...
Im trying to turn on it...but and appears a msg back to...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
