Question about Electrolux Vacuums
Electrolux vacuum short circuit inside the canister
  • ptc9 Sep 30, 2008
    THe model is an Electrolux ap200. There are burnt marks around the area where the plug comes out of the canister. HOw do you get into the back of the canister? I have not been able to find any kind of screws or nuts that would allow me into this area. ANy suggestions????
    Pat
By now you have probably stumbled on another post telling you how to do this, but just in case........
If the vac is not unplugged, do that before starting to avoid any nasty repercussions !
To open the canister there are two rubber bumpers on the sides, peel them off. Under these you will see two plastic strips - open the front of the canister (where the bag goes in) and you will see that these plastic strips are able to slide out of the tracks. Now the tricky part is to get them to move - personally on mine, i took a flat head screw driver and a hammer and "GENTLY" tapped the back end of them (where the cord is), once you get past the "shim" part that keeps them in, they should slide out easily, but keep the vac flat while you do this. Do it for both sides. After this is done, the top comes off. It will rock over to one side, if the bag area is to your right then it will come up and off to the opposite side - careful there are wires for the switch etc under there.
Good luck I hope this helped - I've had mine apart more times than any sane person should - great vac tho !
Posted on Nov 17, 2008
  • 706 Answers
Please elaborate on the problem and if it truly is a short circuit in the canister .. unplug it and provide the model number so that I can help you find the short to repair it.. Have you attempted to open the canister up and look for some evidence of the short ( carbon or burnt wire etc)? Remember to always unplug it before attempting any troubleshooting...
Posted on Sep 30, 2008
Where are locking keys on old electrolux canister vacuum #2100?
not sure what you mean, I assume you are trying to access the inside.Oneach side of the machine there are sliders. The long rubber deal on the sides.Theses slide out..be careful and make sure the machine is unplugged....
Jul 14, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I bought a townhouse with an Electrolux 1561 built in vacuum cleaner. The previous owner didn't leave any instruction manual. It also doesn't seem to be wired correctly as it has to be plugged in...
I don't have an instruction manual, but if the vacuum is running continuously when plugged in you may have a bad relay.
http://www.beamvac.com/usa/support/trouble_shooting.aspx
http://www.centralvacuumstores.com/cvs/trouble_help.php
Aug 03, 2011 | Electrolux Centralux Vacuum
Electrolux canister C104A: Unit shuts itself off and LED in handle next to OFF button flashes.
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
Oct 31, 2010 | Electrolux Guardian Bagged Canister Vacuum
My electrolux O3 carpet power head keeps shorting
If your unit is like ours, there is a electrical short in the wand to Hose connection.. dont use it.. ours unit shorted out and sparks were everywhere.. burned thru the wand to the inside of it and the outside. Good thing my lovely wife wasn't touching that part. electrocution risk was Extreme. PESTER ELECTROLUX, they drag their heels when it comes to admitting and making it right.
Oct 18, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum starts up on its own. The only way to stop it is to unplug it, why is this happening?
The motor can only be switched on this way for 2 reasons. The circuit board inside the canister is bad or somewhere in the wiring in the house or in an outlet, a connection has been made in the low volt wiring, triggering the relay on the circuit board. If you unplug the low volt wiring from the canister and the problem goes away, then the problem is in the house, if the vac still turns on when the low volt wiring is disconnected then the problem is the circuit board inside the vac.
Oct 15, 2009 | Electrolux Central Vacuum
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux C104A does not turn on. won't start. No light on, no sound. Is there any fuse to be raplace and/or ?
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board2.gif could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Jul 06, 2009 | Electrolux Guardian Bagged Canister Vacuum
Renaissance C104A does not turn on. I plugged it in and it does not work.
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
90 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
