Question about RCA RCR311B Remote Control
Issues program the remote.
Got the rcr311bt the other day have tried numerous times to get the thing to program on a sylvania tv. the code that i retrieved from the only time that it did program was not for the tv that i have. since then i have reset the remote and have had it turn the tv off 3 times and doesnt turn it back on. brand code search only one the responded was not the make of tv i have, direct code entry did not work manuel code with retrivial is how i got the code for a different tv that did respond to programing, auto code search has had the tv turn off 3 times and doesnt get the tv to turn back on
Go and buy another remote as this is the most useless waste of time when you keep getting the run around and no answers.what does it take to post a page with all the remote numbers on it they all come with the same page.
Posted on Nov 15, 2008
I have a Sylvania TV with dvd/vhs attached and do not have the remote. I can't get the tv on channel 3 to watch cable. I have tried numerous universal remotes but none of them have worked. Please tell me...
Here is a process to program a Vizio Universal remote. I saved this info to my computer as a text file some time ago. Can't remember where from, so if it works, no credit to me. :-)
Sylvania:10054, 10030, 10171, 11944, 11931
1. Manually turn on the TV.
2. Press and release the TV button.
3. Press and hold the SET button until the LED blinks 2X.
4. Enter your Codes
If the code is accepted, the LED flashes twice after the last digit is entered.
If the LED does not flash twice, repeat Steps 2 through 4 with the next code listed.
5. Point the remote control at the TV and press the POWER button. The TV will turn off.
Vizio Remote Reset
(Use this step if the LED doesn't blink twice after entering the above codes)
1. Press and release the TV button.
2. Press and hold the SET button until the LED blinks 2X.
3. Type 9-8-2, the LED should blink 4X.
4. Now follow the steps above for Programming the TV again.
Jul 07, 2014 | Televison & Video
HELLO, trying to program my sylvania TV with my sony remote. what code do i used ?. my model # is 6413TC. I appreciate any support. Thanks TOM
Hi Forceco,
Please try the universal codes for sylvania TV below.
SYLVANIA Codes: 004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Hope it will works for your unit.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Sep 05, 2011 | Sylvania Televison & Video
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Jan 22, 2011 | Sylvania LD320SSX LCD TV
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
Comcast remote cannot operate Funai/Sylvania LC225SSX tv. Tried all codes, even for all televisions made by Funai. Code search did not work. Comcast tech could not get Comcast remote to work on the Funai...
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Jul 31, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Nov 08, 2008 | RCA RCU600M Remote Control
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
RCA RCR311B Remote Control Logo
133 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
