Question about Dacor DMT2420 1200 Watts Microwave Oven
Ewave Over the Oven Microwave
I was cooking a microwave meal in the microwave. the timer went off and i waited a couple minutes to let the meal cool. however, while i was waiting in the dining room working on the computer, i kept hearing a loud noise. i thought it was coming from next door until i got to the microwave - where the sound was coming from. the microwave was completely dark - no light on the menu/keypad. i opened it and the microwave was steaming hot and smoking but not a bad smelling smoke. i felt the sides of the microwave which felt very hot. the meal was cooked fine! i tried to close the door to the microwave and it started humming again - without any lights turning on. i opened the door and walked away. after about 15 minutes, i heard it beep and the internal light and menu/keypad lights returned. i tried to close the door, and it started running. i hit cancel several times, it beeped when i did it but it did not stop the microwave. what should i do? i can't close the door!
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Power is on, but won't cook
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display. You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key. If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call LG / Goldstar customer service at 1-800-243-0000 to find the nearest authorized servicer. There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad. Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean. Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic. If this is what has happened, it would not be covered under warranty, and it may or may not be repairable. A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out with an air compressor or heat, but often that does not work.
Posted on Nov 11, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Need help with DACOR Microwave model PCOR30S, w/the minute timer
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models (and Sharp models made for Dacor) stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have a very close service manual and have uploaded it to our site here to help you.
You will need the
free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If your model is PCOR30, and you need a new motor, the part number is 66756 and you can order it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Dacor Microwave - Light/Turntable turn on if we close the door
Sorry but I meant to also ask if it will still heat the food when you microwave with it.
I'll assume it does, but if not, please write back and let me know.
This would be a shorted relay RY1 on the control board.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
For details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
prototech@usa.net
Posted on Jan 19, 2009
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Why does my brand new microwave produce lots of internal moisture when heating ready meals?
The new oven is providing more heat to your food, causing more water to boil out of it by the time it is done. It may be OK to shorten your cooking times in response to the higher power efficiency if it bothers you. Then again, maybe you bought a microwave steam oven. They're cool.
Feb 23, 2015 | Microwave Ovens
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
Microwave light and timer work, but no cooking
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Oct 03, 2008 | GE JVM1850 1000 Watts Microwave Oven
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
113 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
