SOURCE: 2004 nissan titan airbag light blinks whats up
you can reset it for free just go to http://www.vehix411.com it will show you how to diagnose and reset the light without a scanner
SOURCE: 2004 Nissan would not start
Try checking your battery and or starter. If not them you might have another electrical problem.
SOURCE: code p0455 evap emission (large)
have the gas cap tested or just replace it, then disconnect the battery for 5 minutes to reset the code, then drive it for a few miles and see if problem comes back, if it does a trip to the dealer is in order, as this may be covered by your emission warranty which is good for 70,000 miles.
SOURCE: my 2004 nissan titan truck wont shift out of park
just a suggestion this may not be your problem but check by your brake pedal for a switch that will be built like the switch that turns out your refriderator lite this switch is a safety telling the shifter the brake is depressed and it is safe to shift out of nuetral, make sure the brake is fully depressing this switch good luck
SOURCE: radio diagram for 2004 nissan
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2004 / Audio
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/white + radio harness or amplifier
Notes: If equipped, the BOSE amplifier is to the right of the steering column, behind the BCM.
Power Antenna N/A
LF Speaker +/- blue/white - blue/red +,- radio harness or amplifier
RF Speaker +/- white/black - blue/black +,- radio harness or amplifier
LR Speaker +/- lt. blue - black/yellow +,- radio harness or amplifier
RR Speaker +/- orange/blue - red/blue +,- radio harness or amplifier
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
This wiring information is being provided free of charge on an "as
is" basis, without any representation or warranty. It is your
responsibility to verify any circuit before interfacing with it using a
digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to
the accuracy or currency of this information. Proper installation in
every case is and remains the responsibility of the installer. DEI
assumes no liability or responsibility resulting from improper
installation, even in reliance upon this information.
Hope helps (remember to rate this nswer)
I have also same issue with my 1998 Honda Passport. Is no check engine light, no codes to determine the problem. I brought my car to the Smog Test twice for the same problem the Evaparative System in their Computer shows "Not Ready". The test center advised me to drive it more 100 miles and I went to them more than 200 miles but the result did not change. And just this morning, I brought it to the Smog Test Center with 500 miles on, it result did not change again, I got the same issued "Evaporative System Not Ready". What is the solution with this problem with no ENGINE CHECK light on?
