Question about Lexmark Office Equipment & Supplies
I replaced my cartridges and now the printer is not working. Should I have it on cop mode? Thanks, Liza
  • 109 Answers
If you changed something and it's broken, it's probably whatever you changed. Take back the cartridges and exchange them for new ones and see if that doesn't fix the problem.
Steve
Posted on Sep 30, 2008
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
I'm getting a a message that says "Left Cartridge
You can try to do the Clean Cartridge function on your printer. While on Copy mode, press Menu -> Tools -> Maintenance -> Clean Cartridges. You can try to insert a known working cartridge to determine if the other is faulty. If your original Lexmark cartridge is faulty, please contact Lexmark technical support and have it replaced. Thanks.
Feb 16, 2011 | Lexmark X5470 All-In-One InkJet Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Info Print 1352 one half faded other half normal print.
You require a replacement transfer roller, if you remove the toner cartridge and look in the printer, you will see a roller which sits underneath the toner cartridge, this is what you need to replace
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Copier not working in color
sounds like a jobg for copier man.
at any rate, you'll find that most likely your cartridges are leaning towards empty, check em first.
Feb 21, 2008 | HP OfficeJet Pro 1170c InkJet Printer
HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
Feb 15, 2008 | HP 83 3-ink Black UV Cartridge Multipack...
Wrong Cartridge Error Message
I have same problem.Please let me know if u find an anser
Feb 10, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Magenta cartridge no print out
firstly check the chip on the cartridge doesnt have any scratches or dents/ bits missing ect and give it a wipe with a dry lint free cloth. if you still get the same you may need to shake the cartridge slightly. hold by the handles and GENTLY move as if your holding a piece of paper wafting a fire. Hope this helps Cops
Sep 13, 2007 | HP Color LaserJet 2600n Printer
120 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
