Question about AT&T Lands Phones
Dial tone problems, no phone
I have service at the test jack, i can unplug it wait a minute and the phone will work any where from a minute or a week or so, also the plug feels warm. I have unpluged every thing that uses phone, computer,satelitte alarm ect, even use one simple corded phone still the same, seems to work for awhile and maybe after rain happens again. but not always. also the red wire on my side of the test jack corrodes, green,i feel it is in the box i can't open? the phone co., says its my problem. any ideas? any help would be appreciated. when the phone don't work the dsl still works. thanks barryrita@bellsouth.net
I saw your free ad so i responded till i got to the end, its not free, wasted my time thanks for nmothing
Posted on Sep 30, 2008
How do I reset my phone to reset to get back in range it says out of range anyone have instructions ?
Unfortunately, I do not have a manual for the GH-4102. However, most cordless phones get out of range messages at a few points: low handset battery, no power at the base or no dial tone at the base. Other possibilities are the phone base and handset lost the registration or one or the other isn't transmitting/receiving properly.
Things to try: unlpug the base power (from both the wall outlet and the phone) and phone line cord and remove the battery from each handset. Wait a few minutes and then reconnect the batteries and plug in the power and data connections. (Check when you unplug the base power adapter if it was warm; that indicates the unit was at least getting power at that point.) Recharge the handset batteries and then re-register the handsets, if needed.
Consider replacing the handset batteries if they are more than a year old (this includes the time that the phone may have been on a shelf after manufacturing). Try a new phone data cable (RJ11).
Next test your phone line and make sure that you have a dial tone. I like to use an old corded phone with the new phone cord for testing. If there is no dial tone, test the line at another jack. If there is still no dial tone, find your incoming phone line and open the service box. If you have a relatively new service, you will be able to plug your test phone into the service box and test there. If you can't test the line or there is no dial tone at the service box, contact your telephone company. They will test and fix outside problems for free.
If the problem is inside, look at all accessible wiring and make sure that the lines aren't damaged. If only one jack is bad, open the faceplate and fix any loose wires. There are two types of connections. The first holds the conductors under screws and the wire must be stripped back and secured. The other uses a keystone jack. The conductor wires are not stripped but a special tool punches the wires into place. You can find the punch-down tool at many hardware/home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring for the jack.
If your phone line has a dial tone and the above fixes didn't work, contact the company and get the phone repaired if it is under warranty (usually 1 year). If it is out of warranty, then decide if it is worth repairing or if you should replace the unit.
I hope this helps.
Jan 09, 2012 | Southwestern Bell GH-4102 Twin Cordless...
My phones say "phone in use", but they are not. Cannot receive calls or dial out.
Whenever I see this issue, I grab an old corded phone as a test phone. The line in use message could be a problem with the phone line or the phone. First make sure that the base has power and try a new phone data cord (RJ-11). Next plug in a test phone to that jack and see if you get a dial tone (preferably with the new data cord).
If you do not get a normal dial tone, try another jack on the line. If you still do not have a dial tone, find where the phone service comes in and open the box. If you have a new service, you'll find an RJ-11 jack in the box. In that case, plug your test phone into the jack. If there is no dial tone or you can't test at the service box, contact your phone company. They will test the line and fix any outside problem.
If it is an inside problem, inspect all visible wiring and open the wall plate if only one jack is bad. There are two standard types of wall plate connections. For one, you strip the conductors and secure them under a screw. For the other, you use a punch down tool to press the conductors (without stripping them) into the right spot in the keystone jack. This tool is available at many home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring.
If the problem is with your phone only, try to reset it. Take the batteries out of the handsets and unplug the power cord from the base and the wall outlet. Wait a few minutes and then plug everything back in. Make sure that the power brick is warm (getting power) and that the handset batteries are fully charged.
If the reset doesn't help, you should contact the manufacturer. If the phone is under warranty have them repair it. (If it is out of warranty, decide if it is worth fixing.) Most of these phones are not meant to be repaired by the consumer.
I hope this helps.
Dec 11, 2011 | AT&T E2718B Trio Cordless Phone
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Handset doesn't have dial tone. says check TEL line.
    For this type of problem, you need to isolate the issue. It could be the phone, the inside wiring, or the outside wiring. I like to use an old rotary phone for testing but any basic corded phone should work. Get a new RJ-11 phone cable as well.
    Unplug the base unit and plug in the test phone to that jack. Check if you get a dial tone. (Try a new cable if the initial one doesn't work.) If your test phone has a dial tone, then the problem is isolated to the cordless phone. (If the test phone works with the new cable, do check if Uniden works with that cable.) Modern phones are not designed to be fixed by the consumer. If the phone is under warranty, contact Uniden Customer Service. (Otherwise decide if the costs are worthwhile for you; there will be a significant delay before the phone is returned/replaced.)
    If you do not get the dial tone, you need to track down the wiring issue. Next move to another jack on the phone line and check if there is a dial tone on your test phone. If there is a dial tone, you have isolated the problem to the jack or the wiring to the jack.
    If there is still no dial tone, find where your telephone service comes in to your building. If you can, open the box. Determine the type of connection used there. If you are lucky, you will find a RJ-11 jack for your phone line. Plug in your test phone and check for a dial tone. If there is no dial tone, contact your telephone provider. They will fix this outside problem for free.
    If the connection is not a RJ-11 jack, you will need to call the telephone company so that they can determine if the problem is inside or outside.
    If you do have a dial tone, then the problem is with the inside wiring. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
    You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
    I hope this helps.
    Jun 21, 2011 | Uniden Cordless Phone
    We cannot get a dial tone on all three of our phones. We tried unplugging them from the wall, taking out the battery and waiting 4 minutes then putting back the power source and putting in the batteries...
    Have you tried a corded phone that does not have any batteries? Unplug all phones and try a phone with no batteries one jack at a time.See if you get dial tone on the phone with no batteries.
    Jan 11, 2011 | Lands Phones
    Phone is not connecting
    Had the same problem with my v-tech portables. I unplugged the main phone from the wall outlet, electric outlet and unplugged the coordinating wires from the base. I also unplugged the extra phones from electric and detached their wires - waited a minute or two and plugged everything back in and waited for another minute or so and what do you know - my phones are working again as good as new!
    May 04, 2009 | Lands Phones
    Lands Phones Logo
    56 people viewed this question
    Top AT&T Lands Phones Experts
    george  peters
    george peters
    Paul C.
    Level 1 Expert
    Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
