Question about Dell 2 Button Mouse 6u226
Mouse left click problem
When I left click on the mouse I get a large + instead of the normal cursor. Did I accidentally change a setting and not know it? The plus symbol is something that I have seen before in my Word program used in drawing word boxes or clip art.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
It is possible you changed the scheme for your mouse pointers.
you can reset it back to the windows default by going to "control panel", then if you are using the catagory view, you would select "printers and other hardware" Next, select "mouse".
( if using classic view, simpy select "mouse" from the control panel).
Next, while on the "mouse" screen, select the "pointers" tab. At the top, there is a drop down menu for " Scheme". Choose either None, or Windows Default, and then click "apply" and then "ok".
Close out all control panel boxes and test.
Good Luck :)
Posted on Sep 30, 2008
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Logitech mouse right click too sensitive
Your computer mouse has preferences to make it easier to use. You can change the style and of the pointer, and you can change the sensitivity, which controls how easy or difficult it is to scroll across the screen. Speeding up the mouse sensitivity can allow you to move your cursor across the computer screen faster, while slowing it down can give you better control but you may have to move the mouse a greater distance to get your cursor to where you want it.
Click the Windows "Start" menu and type "mouse" into the Search field. Click on the "Change Mouse Settings" link in the search results. Click on the "Pointer Options" tab. Move the Motion slider bar to the right for a faster speed and to the left for a slower speed. Click "Apply" to apply the settings. Move your mouse to see if those are the settings you would like. If not, adjust the slider bar again. When you find the right setting for you, click "OK" to save the settings and close the window.
Jan 23, 2013 | Logitech Wireless Keyboard & Wirelss Mouse...
Slow curser using mouse
The cursor speed can be changed in the mouse settings in control panel ..Just open the control panel ...choose mouse..and after that in general select the mouse speed (there is a slide cursor that allows you to choose a better speed..)
If it is still slow..it may be caused by a wide resolution chosen in the settings ..and the mouse is not made for it ..There are mice made for large resolutions ..and they move much better ..(there is no difference in price ..but they are just a new generation and made this way cause most computers evolved to using large resolutions on screen ) ..
If your mouse is a few years old ..this is for sure the cause..It will speed up a little if you change the settings but still be slower than most new ones..By the way ..if you choose pointer in the mouse settings will show the pointer speed setting ..on the first screen will be just the double-click settings ..have a nice day !
Dec 29, 2011 | Computers & Internet
Tool bar moved t right and is large
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?)
Make sure "Lock the Task bar" is not checked
Click on the border of the task bar
drag directly from where you clicked to the bottom
Adjust height accordingly
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
Curser turns to circle with black line through it
Hello, Try changing the cursor's color with these detailed instructions:
No. Mouse actions Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Mouse pointers:
  • Select a cursor and pointer combination.
  • Select Save.
Under Mouse pointers, select a cursor/pointer combination by pressing:
  • ALT+R for Regular White
  • ALT+U for Regular Black
  • ALT+G for Regular Inverting
  • ALT+L for Large White
  • ALT+B for Large Black
  • ALT+I for Large Inverting
  • ALT+X for Extra Large White
  • ALT+K for Extra Large Black
  • ALT+N for Extra Large Inverting
  • Select Save by pressing ALT+S.
May 06, 2011 | Compaq Computers & Internet
Left handed use of dell mouse
go to control panel, double click 'mouse', look at 'buttons' tab. Change as needed!
Aug 13, 2008 | Computers & Internet
Large icons
hi, goto desktop properties, settings, advanced, there in general tab, change the DPI settings to Normal size(96 dpi) and click OK, and restart.
If this did not work let me know.
Jun 27, 2008 | Compaq Presario 5000 PC Desktop
How can i change my mouse cursor??(flower)to the normal pointer just the arrow one..
ok fallow these steps
clike start menu>settings>control panel>mouse>pointer>go to scheme and select none and apply changes.
your mouse cursor will become normal.
regards
gaurav rajput
Feb 12, 2008 | Computers & Internet
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Dell 2 Button Mouse 6u226 Logo
1,292 people viewed this question
Alun Cox
