Question about GE JGRP17 Gas Single Oven
The oven broiler work but the baking part doesent.
I have a GE oven and when i wanted to bake the baking oven dosent work but the broiler part does. it has one of those pilots that heat up bright red and the oven goes on but the broiler part does go on to set on the broiler but when i press bake to certain temp the stick does not glow red and nothing happens. but the broiler pilot does.. what is wrong with my oven... please help....ps the top ranges do work and its a gas stove
thank you so much
  • luigys22 Sep 30, 2008
    thank you
    actually the ignitor for the oven is on top ( the one that does not work) and the broiler ingitor on the bottom ( the one that does work )
    where can i find one and about how much do these cost or is it cheaper to buy a new range?
    thank you so much again
  • Anonymous Mar 16, 2014
    What would keep the oven/broiler from lighting? I can set the needed temp, but the clicking noise that happens when lighting occurs doen't happen. Please help
  • 943 Answers
Hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Posted on Sep 30, 2008
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
I just moved into a house and it came with a ge oven the but it doesn't have bake or broiled written by the knob how do I know which way to turn the knob
generally bake is the up position and broil is the lower position just try each way the broiler is on top of the oven and bake burner is on the bottom.
Nov 09, 2010 | GE Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE oven bake igniter is bad ?
Yes, it should work fine to swap them. (fortunately the bake and broil igniters are often the same part number on GE gas ranges, as as opposed to many other brands) Of course now you broil will not work, but you should be able to get your oven going again.
Jul 15, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
823 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
