I have a HoMedics Model SBM-350 double shiatsu massaging cushion. Used it incorrectly by lying it flat on floor and lying on it. It now makes a noise like a jack-hammer. Opened the back by unzipping the cover and it appears that the 2 large white gears are not working. Only one is turning. The noise appears to be coming from the area where these 2 wheels meet.
  • 2 more comments
  • coopbulldog Sep 30, 2008
    No the wheels don't appear broken. Can't see enough into product's "insides" to determine if there is a "slot". One wheel just doesn't turn.
    I think I lost the Tech who was trying to assist. I have a HoMedics SBM-350 Double Shiatsu Massaging cushion. The 2 white plastics gears that move the massaging units from lower back to upper back are making a "jack-hammer" noise. One wheels turns and one does not? The actual massaging units still turn but the noise is bad. Additionally, the remote control (attached by a wire) has locked up and I cannot turn unit off unless I unplug it.
    Take it to a repair shop? That's the best you can do? That's fine but your not telling me anything that is helpful.
  • Pearliemae57 Jan 16, 2009
    I got it new and used it for only about 20 minutes and it did the same thing. I was using it properly on the sofa.
  • 6,487 Answers
There's a possibility that some piece of it was detach why you have this problem and you may need to fullty open the unit and check if there's any broken piece inside it that may also need to be replace ...
Hope that helps......
Posted on Sep 30, 2008
    Master:
  • 763 Answers
Do you have a warranty for that? or maybe you should put some grease on it or something. it should be send to repair service to replace some parts.
CHARCOIS
    Scholar:
  • 148 Answers
I WOULD LIKE TO KNOW IF THE WHEELS IS KINDA BROKE OR THE SLOT ATTACHED INTO IT WAS BROKE.. DID YOU SEE ANY OTHER SMALL PIECE THAT U THINK IT WAS ATTACHED TO IT..?
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 30, 2008
    MAY I KNOW WHO'S THE EXPERT THAT ATTEND TO YOU EARLIER..?
Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunki
mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
Oct 13, 2017 | Homedics Quad Roller Massaging Cushion...
HOW TO FIX smb400h homedics cushion
Hi
Kindly advise what is wrong with your cushion or kindly advise how your cushion is malfunctioning before i advise you further.We can order the necessary spares &repair.
Jul 05, 2014 | Homedics SBM 300H Therapist Select Shiatsu...
Conair massager model 4502ST
I have a homedics shiatsu massaging cushion model SBM-300. I have lost the power adapter. The box says 120VAC/12VDC 1A. I cannot find a replacement anywhere. Any help would be appreciated. Thanks
May 02, 2012 | Conair Heated Back Massaging System Bm1
Need a power adapter for the homedics sbm300 massager
No longer available from Homedics. Just called them today and found this out.
May 29, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
May 03, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Wiring poitive and negative
Hi, I have an SBM 500H massage cushion without that AC-DC adaptor... may I know whats the working DC Voltage in Volts and DC Current in amps it works on? Kindly, email me at stycch@yahoo.com... Thanks!
Feb 04, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
Nov 27, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Computers & Internet Logo
553 people viewed this question
David Payne
David Payne
