Question about Samsung Office Equipment & Supplies
Installed a sampson printer ML-2510 but it will not print a test page or anything
I do not have the problem resolved at this time. I bought this printer and set it up and ibstalled it with the proper disk enclosed with it. The printer will print it's test page when yoy hold down and release the yellow buttom. The printer will not print anything that the computer sends to it. I thought that your service was part of Samsung's help amd that it was Free. I will continue to resolve this problem as I hav been busy with other work and have not had the time to work on it right mow.
Posted on Oct 01, 2008
I installed a new cartridge and now only 1 page printed. It was a generic cartridge.
It's likely dried out. Print a few test/calibration pages, or try to print a few pages of heavy ink-usage. If that doesn't open the flow, you'll just need to replace it.
May 05, 2011 | Samsung ML-2510 Laser Printer
Page prints, but jams, samsung ml 2510 and toner is smeared over page
Your toner might be faulty, also remove toner and clean place with a cloth. Look to see inside if their are any loose pieces of paper in machine.
Feb 21, 2010 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
Valid page names message driving me nuts
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
Jun 28, 2017 | Samsung ML-2510 Laser Printer
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
ML-2510
can you do a test page to verify if you have a printer or software driver problem...
Press and hold the Cancel button for about 2 seconds.
A demo page prints out.
Make sure that the
Online LED on the
control panel lights
green.
• If the Online LED is off, check the power
cord connection. Check the power switch.
Check the power source by plugging the
power cord into another outlet.
• If a demo page does not print, check the
paper supply in the tray.
Print a short document from a software application to verify that the computer and printer are connected and are communicating correctly.
• If the page does not print, check the cable connection between the printer and the computer.
• Check the print queue or print spooler to see if the printer has been paused.
• Check the software application to ensure
that you are using the proper printer driver
and communication port.
more info required
Nov 13, 2007 | Samsung ML-2510 Laser Printer
60 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
