Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
Toilet water wont go down
When i flush my toilet all the water and everything in it comes to the rim of the toilet and wont go down after a min or two it will go down a little just under the rim i have tried everything plunging it and it don't works cleaning the little holes that the water comes out of don't work
  • 374 Answers
I have found on many occasions this problem was caused by an obstuction in the internal trap of the toilet. Everything from toothbrushes to Batman figurines have been removed from them. If you intend to do the repair yourself you can use a closet augerwhich is a manual cable snake tool that will be inserted into the bowl of the toilet and the cable ran through the toilet's internal trap to clear obstructions. You could also rent a hand held electric auger that is basically a drill with a drum attached with a drum with coiled cable inside that is shoved down the channel the same as the aforementioned product. This device take a bit of finesse and skill as the cable will try to kink and coil up as you go one can get injured doing this. If you find that the toilet is clear of internal obstructions you may have to pull the toilet up as the obstruction may be further down the line. If you rent a medium sized electric auger you can locate the vent stack for the toilet and run your cable down the vent from the roof so you may not have to pull the toilet. This method will only clear obstructions behind the vent connection and not the length from the connection of the vent to the toilet itself. If yo have an elevated house you may have access to a clean out that by most codes are at every change of direction greter or equal to ninety degrees. You also should test your water pressure if all else fails as that specific model must have at least 25 psi at the very least to operate correctly. Hope this helps you out.
Posted on Sep 30, 2008
I have a Sloan m101526 toilet tank and it's constantly making a running /hissing noise. At first it was just a drip noise then more then like a flowing noise.
Lift the top of and look. It will either be the flapper in the bottom is being held up by the chain or something, or the inlet valve is faulty. Flappers do wear out and warp. If you get 4 or 5 years you are lucky.
After typing this, you have a Flushmate in it. I would call a plumber!
Sloan m101526 toilet tank Google Search
Jan 11, 2017 | Sloan Home
When filling, the toilet makes a loud noise like a water buffalo dying and wont stop until I turn off the valve. whats the deal?
That miniature water buffalo may be living inside a clogged fill valve. It may be necessary to replace the valve to regain peace and quiet. If you do replace the fill valve, be sure to flush the water line first in case any debris is lingering.
Jan 09, 2017 | Home
Our Costco Water Ridge toilet won't flush unless we hold the button down for a while. Sometimes we have to do that twice.
You need to contact the manufacturer of the toilet. If it was recently purchased, there should be a warranty. Otherwise, they can probably tell you what parts are needed to repair it.
Jan 07, 2017 | Home
Fix minute hand
Sounds like (without being able to see it) that the min. hand has come off its holder. Most likely have to take clock apart. If there are no screws, it should just be pressed together.
  • Pry it apart with plastic utensil, less damage. Dont force anything.
  • If you can get that face off the min hand just needs to be reattached to its mooring simply by pressing it on. Of course you would check for any other possible damage. But that should be it .
  • Then put it back together.
Jan 12, 2015 | Home
I have a push button flush on my toilet but the flush is getting less powerful and we have to wait ages before it will flush again despite the water level filling quickly????
Sounds like the syphon unit has scaled up. You can try flushing with a descaler fluid a couple of times to see if that will loosen the scale but otherwise replace the plastic syphon within the system. Cheap part, relatively easy fix if you know bit about plumbing. Confidence is the key.
Dec 13, 2014 | Home
Toilet leaks in front of it. have check the water lines to it and no leaks
The wax ring is leaking. Go to a hardware store and they should have one and explain how it works. You will need to pull the toilet though, to replace it.
Jun 09, 2014 | Home
Mytoiletdontwork
There are lots of eco friendly toilets and if you have one, this is a common problem. You will have to replace the whole thing.
Jan 20, 2014 | Home
Wont go off
-You're talking about water not car right...?
-Shut off main water line and remove the on/off valve, if lose or broken
screw that hold the washer or broken washer. Possibly fixable or just replace new one.
Then turn the main water back on again. You should be good to go.
mai
Apr 11, 2013 | Home
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
1,460 people viewed this question
Top Eljer Home Experts
john h
Mike
Gene Lawson
Are you an Eljer Home Expert? Answer questions, earn points and help others
