Question about Sony Computers & Internet
SILLY QUESTION. how CAN I GET a WRITTEN Answers About The Key Letters F1 To F 12. What Each Function Key Means.Thank You Paul Lavigne
  • 981 Answers
The F-keys are just keys. If they had proper meanings they would have glyphs assigned like @ or % or $ or R. If you want a cheat-sheet about the uses of the F-keys in various programs, take notes in a program or on paper and print a cheat-sheet out. It beats buying another screen just to display that info, epsecially with the number and variety of programs out there.
Within the scope of a certain BIOS or OS environment, e.g. the desktop or Microsoft Word in normal editing mode, they can have particular meanings. Accordingly, you can buy neat plastic templates that fit down in your keyboard (from Global Supply, or Corel, or various publishers and special interest groups) or office supply stores, and get some intuition on how to work more efficiently.
I hope I'm answering what you were wondering about!
You know, in Linux, a keyboard with multimedia volume control keys generally has to be set up so those keys mean something manually. On the other hand, you can set up stuff you really want done.
Posted on Sep 30, 2008
How do I use the prtsc button on toshiba ? It has END/prtsc. THANKS
If the 2 words written on the key are different colour then you might have to press the Fn key + End/prtsc for one of the options. If they are both the same colour then the Shift key + End/prtsc.
The Fn key has the same colour letters as the key which is pressed with it to perform a particular function.
Jan 26, 2012 | Computers & Internet
My grand daughter has some how turned on the FN key so when she is typing numbers come on the screen instead of the letters. How do we stop this ?
The NumLkkey has been pressed andthe letters on the righr hand side on the keyboard has been converted to a number pad.
The NumLk key also doubles up as the ScrLk key, this is located near the F12 function key. Whenyou press this key to turn on the Numlk a LED will light up to indicate that the Number Lock has been pressed, press this key again to turn off the Number Lock and the NumLk LED will switch off and you will be able to type letters again.
Aug 29, 2011 | Fujitsu Computers & Internet
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
Jul 12, 2011 | Computers & Internet
Please advise if there is any step/key that could release the use of key with blue note function. i.e. on "M" key, the blue note is "0", if I could not release its blue note...
There is function key in your laptop which is blue in print and written Fn which means there are some keys like u say 0 written on M it is zero in numbers which work only when u have switched on your numlock.To get back to M switch-off numlock.
Jan 05, 2011 | Samsung Computers & Internet
How to unlock keypad of q mobile e900
Try this.
It stumped myself and some true experts once. We were having problems with the keyboard in a darkened room.
There is a Function ( "F" or "FN") key on the lower left of the keyboard. It's labeling is often blue in color. In low light conditions, you cannot see the blue coloring. It is used to turn a section of the keyboard into a calculator. That section will have dark blue numbers written on the keys that change function. For example the K may have a dark blue number 2 written on it. In other words, When you type the Alphabet you come up with some numbers substituted for letters and not all of the keys may function.
IN YOUR CASE PUSH THE FUNCTION KEY DOWN AND WHILE HOLDING IT DOWN PUSH THE KEY FOR THE CALCULATOR. IT SHOULD THEN RELEASE YOUR KEYBOARD FOR NORMAL USE. Hope this helps you.
Best Regards,
Mark
Dec 30, 2010 | Computers & Internet
Some letters of the keyboard wont function especially the backspace.
Try this.
There is a Function ( "F" or "FN") key on the lower left of the keyboard. It's labeling is often blue in color. In low light conditions, you cannot see the blue coloring. It is used to turn a section of the keyboard into a calculator. That section will have dark blue numbers written on the keys that change function. For example the K may have a dark blue number 2 written on it. In other words, When you type the Alphabet you come up with some numbers substituted for letters and not all of the keys may function. Give it try.
Best Regards,
Mark
Dec 26, 2010 | Computers & Internet
The keyboard on my ACER Aspire is stuck in a mode...
Find the key that says num lock, press the Fn key and the num lock key to turn off the number lock.
Jun 16, 2009 | Acer Aspire 3000 Notebook
Typing problems
I have a cat that has probably written the Great American Novel by now, so I sympathize. Please check to see that the numlock key is not depressed or the shift/function key combination will not solve your problem.
Mar 29, 2009 | IBM ThinkPad R31 2656 Notebook
Cassette tape stuck
no question is silly ,it may draw juice if the power it's direct,when you turn the key on off and the cassette is still movinig or ,at the same time do this push eject & with a some thin screwdriver or pencil pull cassette out this is an old trick help me menny of times..good looking
Dec 09, 2008 | 1999 Ford Taurus
Computers & Internet Logo
97 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
