Question about GE DSKP233EWWH Electric Portable Dryer
Dryer belt loose
But it new one it but how do tight
  • 4 more comments
  • faceoff1 Sep 30, 2008
    belt is fix ok i had the pulley up side down , but there is on the motor a sliver nut like on the motor
    does the belt go around that and does it make a different if falt side up or down , the belt is tight
    cause motor stll isn't turning the tub ok motro work timer does it need to retime with new belt on now ?
    motor pulley is that the white wheel in that case then , well the belt it self there is the flat side and there the grooves side is down on the sliver nut groove ok the white one that place in front of the tub itself flat is showing ok, but now is tight will this turn the tub now ?
    thank you very much for help well stay in contact with you on thing's from time to time ok
  • faceoff1 Oct 07, 2008
    well the dryer was working but it was trunning to solw to dry load of clothes ok so , i loose it up now to i retight the blet back up now please thank you
  • faceoff1 Oct 08, 2008
    ok i'm redoing the tighing of the belt sorry for spelling the word ok i'm mad as well you know cause it time to take screw's out you know , thank you for being there you have know i deal how much that you help eeven it was just a little bite ok still thank you and i be back on here in a few minute ok
    i cant afford that ok if i could i would
  • 943 Answers
Hi thanks for the question . from the back panel ,where you can see the motor, and pulley . bring belt to left pulley push down on pulley. now put belt on motor pulley. let go the left pulley . thanks the appliance doc
Posted on Sep 30, 2008
  • john gagnon
    john gagnon Sep 30, 2008
    hi the belt has to go around the motor pulley and on the idler pulley and the grooves on the belt face towards the drum
2 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Posted on Aug 28, 2008
What does it mean if Dryer hums upon start and nothing happens?
The belts turning the drum are to loose or broken. Replace belts
The motor has a internal problem after about a min if you smell something burning Replace Motor
The drum might have come loose and slipped out of place. Remount drum and ensure all screws nuts and bolts are inplace and as tight as you can manage
Apr 24, 2014 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Managemylife com
See if there is a pulley on the belt that can be moved to tighten the tension. Often the motor's mounting bolts can be loosened and the motor itself can be moved to tighten the belt and restore friction. If not possible, a new tight belt is in order.
Nov 23, 2013 | Maytag Dryers
The small belt in the middle of the drum broke. After I pulled the drum off I noticed a small plastic wheel on a metal bracket loose in the bottom of the dryer. I can not see where this reataches and I...
its called an idler arm, it attaches next to the motor as this is what keeps tension on the belt so it will stay tight on the drum. If I remember correctly there is a slot on the bottom of the dryer close or right next/past the motor, slide it into that slot, with the small plastic wheel up next to/by the motor. I am attaching a diagram for the belt it will help. Good Luck and I hope I helped Tim:
http://www.applianceaid.com/images/belt-config.JPG
Remember the belt should ride in the middle of the drum and the back of the drum is lipped and should go behind the drum rollers. Once the belt is thread it will be tight and the idler arm will not longer be loose.
Mar 12, 2011 | Whirlpool LER4634J Electric Dryer
The dryer will heat up etc but will not spin...any suggestions?
there is a belt that goes around the drum and is attached to a pulley at the bottom. you will need to unplug the dryer access either the front or back and check to see if the belt is tight. if its loose or snapped off, you may have to purchase a new one. it's cheaper than replacing it with a new dryer. good luck!
Jul 19, 2010 | GE Dryers
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
How do I change the rubber wheel under drum on left side? The wheel on right side is fine and tight. Left side very loose and causing dryer to be very loud.
On a front load machine, you would remove the front of the dryer, remove the drum belt, and lift the drum out of your way...then install your new roller...reassemble.
Sep 20, 2009 | Whirlpool Dryers
Dryer belt does not apear to be broken but cannot see what pully is broke or other problem
if the belt isnt broken,and just loose then check your "idler" pulley,its on a spring steel bracket by the motor and it keeps the belt tight thats more than likely the culprit from your description
Aug 24, 2009 | Amana NGD4500VQ Dryer
New belt but drum still won't turn
make sure that he put the tensioner on the right way with the spring it will make the belt really tight !This is sometimes hard to do because the spring will bite you if your not careful !!
Feb 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Tensioner
yes it keeps the belt tight so it can turn the drum. its like a pulley that keeps the tension on the belt so that the tub can spin etc.is the belt tight now or is it loose?
Aug 11, 2008 | Dryers
Belt Not Tight
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
Jun 26, 2007 | GE DPSR483EA Electric Dryer
GE DSKP233EWWH Electric Portable Dryer Logo
598 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
