Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge Hi Thanks for the advice on the fridge -- I dont have an ohm meter, how can I visually tell if the heater is bad? Do you know if this part is under warranty? Here is my original message, you wrote back that it is probably the heater -- HI I have the panel inside the freezer off and am looking at the totally snow covered coils -- what do I do now? How do I know which part is causing the defrost problem? GE side by side model # GSH22JFTACC Thanks
  • 1,543 Answers
The defrost heater is a coiled heating wire inside a glass tube. The glass tube is usually not the easiest to see through, but you may be able to see a break in the wire. It would not hurt to apply 120 volts across the element. A good defrost element would then begin to glow red in just 10 or 20 seconds. Warranty is one year on parts and labor. Be sure to melt all frost off evaporator using a hair blower before reassembly.
Posted on Sep 30, 2008
Hi, i have a Westinghouse Virtuoso stainless steel fridge with the freezer on the top. modelcode is RJ423V-R*4, it is freezing the fridge contents and i cant stop it from doing so, can you help plz?
Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM
Fridge/freezer freezing up- and no fan or air circulation:
first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
https://www.youtube.com/watch?v=6SJN8oaA2XE
https://www.youtube.com/watch?v=buX9KcZo2c0
https://www.youtube.com/watch?v=gVXT7pZyk_o
https://www.youtube.com/watch?v=53ZFeiWgtuk
God is so good: so this is why I give free advice so please thank him not me.
Kenmore Whirlpool refrigerator frost build up in freezer not cooling... Freezer Frost Repair Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM
Dec 16, 2016 | Westinghouse Refrigerators
We are trying to help this single mom, she has a ge fridge side by side model no. GSH25JGBBBB, THERE WAS A 5 MINUTE POWER OUTAGE, WHEN EVERY THING ELSE CAME ON, THE FRIDGE DID NOT,I CANT RUN A SELF DI
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God is good that's why I give free advice?
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER though seldom CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
Sep 02, 2014 | GE Refrigerators
CHECK DEFROST SYSTEM PARTS
You can use an ohm meter to check the heater and thermostat, but you will have to disconnect them before ohming them out. You should get low resistanc readings, if you get an open (infinity) reading, they are diffently bad.
Unfortunately, the other two can't be checked without special test gear that is pretty expensive. My suggestion is to check the thermostat and heater and if those aren't the problem. GO to a known appliance repair shop and have them check the other two. They will probably charge you about 20 bucks to check them for you.
Hope this helps!
Hal aka ImJustAvg
Jan 30, 2012 | GE Refrigerators
HI there, My GE does not make ice in ice compartment, but ice built up entire back wall of refrigerator, I already try to cut off the water line, but the problem the same. Please tell me why? and how do...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Feb 28, 2011 | GE (GTS16BCS) Top Freezer Refrigerator
How do you test the defrost heater to see if it is functioning? We had same issue several years ago and the defrost heater was the issue. Before we buy parts, is there a way to test to see if that is truly...
You can remove the wires from the heater and using a volt/ohm meter set for ohms,test the heater terminals. If it reads it is good. If it does not read it is bad.
Or,you can force the fridge into the defrost mode and wait for the heater to come on. Find the defrost timer and turn it to the defrost setting.
This being a GE refrigerator it is probably the heater and the defrost thermostat.
Aug 30, 2009 | GE Refrigerators
GE side by side refrigerator
Mike, Most times when this happens it's the water control valve for the ice maker side that becomes defective. If using an OHM meter you unplugged the 2 coils and read the OHM's they should be very close to equal. The part number for the water control valve is WR57X10032 and the part number for the ice maker is WR30X10093 Unfortunately the ice maker is electronic and there are no replaceable parts. You can test the ice maker by filling with tap water allow to freeze and if it dumps then the ice maker is good and the water control valve is bad, Thanks, Please Rate Me, Sea Breeze
Aug 29, 2009 | GE GSS20IEM Side by Side Refrigerator
GE refrigerator gsl25xgwss defrost problem
Either heater or Board is most likely bad. You can remove heater and test it with ohm meter for continuity
Oct 05, 2017 | GE GSL25XGWSS Stainless Steel Side by Side...
Ge fridge
Most likely it is the defrost heater. (it's that thing at the bottom of the coils with two wires leading from it.) To test it for sure, you'd have to use an ohm meter, but many times you can visually see that the heater is bad. Defrost the coils with a hair blower. If you don't have the heater on hand, the refrig will work fine for a week until you can replace the heater.
Sep 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator TBX25zpk coils Freezing
It's almost always the defrost heater. If you have volts to the defrost thermostat the defrost control is working. Set your meter to check ohms and remove the wiring from the heater. If anything changes when you touch the meter leads to the heater terminals then the heater is probably good, but my guess is nothing will change, which means you've got a bad heater.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
