Question about Electrical Supplies
House lamp switch on cord not connecting
Hello, I a number of desk top lamps in my house where the switch is part of the cord. The majority of the lamps flicker like crazy when I turn them on and often I jingle the cord so I can get a connection. Can you help.
Jenny
    Scholar:
  • 62 Answers
I have never been a big fan of these type switchs for this very reason. This type of "in line" switch usually has two halves, that fit over the cord. It could be that the screw that holds the two halves together could be loose. If this connection is tight, then, depending on what type of switch this is (there are several types), it might or might not could be repaired. THEREFORE, I would suggest a trip to the hardware store or department store, and buy a new switch (Wal Mart carries 2 types of these type switches). The instructions will be included with the switch, and it is easy enough for most homeowners to easily repair, most of the time with only a screwdriver. And as long as you have the lamp unplugged when you repair it (PLEASE!), there is no harm of being electrocuted.
I hope some of this helps!!
Chad
Posted on Oct 08, 2008
    Novelist:
  • 103 Answers
These in-line switches are also very unfavourable for me also......as chad7houston mentions above...some are screwed together but there are also the ones that simply pinch the wires throught the insulation and the 2 halves snap together without any screws......these switches arc and deteriorate every time you switch them and they get worse each time......it's best to replace the entire cord with a new switch because the cords used with those lamps are also not very good....good luck
Posted on Jun 28, 2010
How to remove a dog house engine cover on 1992 chevy van g20 with map lamp and power window buttons attached
Bolts and or clamps at the top and on the floor. Lamp and switch wires can be unplugged
Sep 11, 2014 | Cars & Trucks
Tensor Desk Lamp with magnetic off & on switch stopped working. How can I fix this
Do you have the model number? This is most likely not the switch. There is a problem with the power suppply. IT uses capacitors that have been substandard and may have failed.
Dec 04, 2013 | Tensor 2 x 3W LED Desk Lamp
Proform elliptical - totally dead. help?
1) must shure if the electrical power from your house is o.k reset the c.breaker or replace blown fuse, test with lamp desk.
2)test the power cord if are open, or break, or burn
3)clean the contacts batteries with alcohol 100% from oxide, dust, corrosion.
4) Resolder any wires and connectors clean and tight very well.
5) tights the bolts from your machine attached.
6)Verify now.
Jun 21, 2012 | Exercise & Fitness
My pro form elliptical is no longer getting power using the ac adapter. Unplugged it to paint the room. Now there is no power. Any help?
1) Measure the outlet plug with another device such a lamp desk 115Vca.
2)If there are voltage with the lamp , the problem is with the fuse+c.breaker in your treadmill.
3)If there are NOT voltage with the lamp, the problem is c.breaker from your house Reset.
4) If after you reset there are NOT voltage again, the problem is the wires had been isolated with the paint, You must take out the paint, for to conduct the electricity to the outlet, and try again with the lamp desk
see the diagram.
God bless you
May 11, 2012 | Proform Exercise & Fitness
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
Electric problem
Is it a FAV6800a or FAV9800a machine?
Have you checked the 120VAC outlet for power. Plug a desk lamp or other device into the washer outlet and make sure 120VAC is present. If not check the breaker/fuse load center for a tripped breaker or blown fuse if a old house......Rich
Jun 22, 2010 | Maytag Neptune FAV6800AW Top Load Washer
New Bulb in my In-Focus Lp130 wont light
the connection that the lamp plugs into backs out of place preventing the connection from being made. you will have to remove the top. with thetop off, install the lamp and look to see if the lamp connection is going into the connector on the lamp housing. if not, you can get a flathead and push the connector into place on the lamp housing and hold it there while pushing the lamp into place. to keep this from happening again I always used to melt the connector to the lamp housing with a soldering iron.
May 26, 2010 | InFocus LP 130 Multimedia Projector
Replacing cord on table lamp
From one side of the lamp cord, to one side of the switch.
From other side of switch to both blacks from the upper and lower bulbs.
From other side of lamp cord, to the white coming from both bulbs.
This assumes there is a black and white wire coming from both bulbs.
Please note, look at the lamp cord closely, particularly the plug. If one prong is wider than the other, then the plug is polarized, and you need to pay special attention to the wires leading out of the plug. One of the two will be ribbed, the other smooth. Note which is on the same side of the plug as the wide prong. Whichever is with the wide prong, should NOT connect to the switch, but to the whites coming from the bulbs.
Feb 12, 2009 | Alert Electrical Supplies
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Dec 24, 2006 | Canon LV 7345 Multimedia Projector
Electrical Supplies Logo
517 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
