Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Blinking green timer light and fan turning on randomly, now no power at all
I have a WD-62530 that I got from Costco about 2 years ago. Last Wednesday morning it worked fine, came home from work and the timer light was flashinh green and the fan kept turning on and off. IT wouldn't turn on and had no sound. I unplugged it and was out of town for the weekend came back today and now nothing, not even the green timer light when I plugged it back in. Anyone have any ideas?
  • 1 more comment
  • Anonymous Oct 24, 2008
    Green power lite keeps blinking and I can turn on the tv.
  • Anonymous Oct 31, 2008
    Blinking green timer lights and I can't turn on tv
  • stevekrop Oct 31, 2008
    Blinking green timer light, can't turn on the TV
  • 80 Answers
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
thanks
scott
Posted on Oct 16, 2008
I have the WD-65731 DLP HDTV. The tv will not turn on. Initially, it will power up, and you can here the fan running. The green "timer" light will blink for several seconds. Finally the fan will...
Have you replaced the lamp?? You usually have to replace the lamps around every two to three years. The manufacturer has designed it so you the customer could change it yourself without a technicion. Hope this helps.
May 25, 2011 | Mitsubishi WD-65731 65" HDTV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have a mitsubishi dlp WD-65733 and it went out on me a week ago. when I power it up i get only the green light above the timer. when i hit the reset button in the front i hear a click in the back and the...
It seems problem in power supply board that got few electrolytic capacitors leaky and causing problem. It does not look like lamp issue.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board?
Thanks.
Apr 06, 2011 | Televison & Video
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
