Question about Lexmark T642 Laser Printer
Close door or insert cartridge
I had just pulled the T642 out of the box, reseated the cartridge after removing all the tabs necessary. Power it on and i get this message saying close door or insert cartridge. I have tried 3 different cartridges, checked the door hinges and sensors to make sure everything looked ok. No matter what I do it gives that message after it boots up.
  • EATech Sep 30, 2008
    Thanks Corysf62, I had already figured out the problem before I even got back to my desk and saw that there was a response. With me being like curious george I couldn't help but start to take that door apart and find out whats not connecting. On the switch itself (little as it is) the metal lever that helps it push the button in was not even on the switch. Manufacturer mistake i guess. I just cracked open the lid to a T632 we have for spare parts and took the little metal lever off of it. :) All's good now. :)
  • khahn Oct 03, 2008
    Hello, I having the same problem. I checked the hinge on the left side and it seems to be there. I even tried a new toner. Any other ideas? Maybe I am missing something. I found a little Y type small metal peace laying on the left side of the printer. It looks like it has 2 clips on it. Any help would be appreciated. Thanks!
    Genius:
  • 1,913 Answers
Check in your backside of printet any paper jam
pull that paper thats it.
also pull the cartridge and refix again it
Posted on Sep 30, 2008
    Novelist:
  • 188 Answers
The reason that the error message is vague and says to close door OR insert cartridge is because it doesn't know which condition is causing the error.
There is a switch, located in the left hinge, on the front cover that must close for the printer to work.
When the cover is closed AND a cartridge is installed, part of the cartridge pushes the spring clip on the switch to the closed position.
If there is no cartridge, then the switch can't close, but like wise, if the cover is open, then the cartridge can't hold the switch in.
The problem I have seen with this printer many times, is that the silver actuator part of the switch actually falls off of the switch. There is nothing for the cartridge to press against, and therefore, the switch will not close.
If this is in fact an out of box failure, 95% of the time, lexmark will simply send out a replacement printer to exchange for the one that failed, but even if they do not exchange it, it is covered under warranty and they will send an onsite technician out to you to replace the part.
They would normally replace the entire front hinge assembly, part number 40X0006, which includes the switch. The number for Lexmark is 1-800-539-6275 Mon - Fri: 9 am - 9 pm & Sat: 12 pm - 6 pm
Good Luck.
  • Cory Friedman
    Cory Friedman Oct 11, 2008
    HI Kha...
    If you re-read my original answer, you will see that the silver piece you found is exactly what I was referring to.
    That piece is PART of the switch assembly. When the door is closed on the printer, part of the toner cartridge casing slides up and presses on that silver piece and actuates the switch.
    Since that part came off the switch, there is no way for it to become engaged.
    If you can, remove the switch from the hinge, press the two side pieces together SLIGHTLY so they are more snug, and reattach to the switch, then reinstall it.
    This WILL fix the problem :)
This repair worked like a charm for me. The little metal piece just pops right in when you take the switch out.
Posted on Oct 28, 2008
How do i install a new cartridge
Welcome to FixYa!
Toner cartridge replacement for HP LaserJet 3055.
Press the cartridge-door release to open the print-cartridge door.
Remove the print cartridge from its packaging, and then rock the cartridge gently five or six times.
Bend the plastic tab at the end of the cartridge.
Pull the tab until all of the sealing tape is removed from the cartridge.
Hold the print cartridge by the handle and insert it into the all-in-one and then close the print cartridge door.
I hope this helps.
Thank you for using FixYa!
Jas247
Apr 02, 2011 | HP LaserJet 3055 Printer
We are not able to replace the cartridge and also not receiving any incoming fax
1. Open the print-cartridge door.
2. Grasp the handle on the print cartridge, and then pull the cartridge straight out to remove it. See
the recycling information inside the print cartridge box.
3. Remove the new print cartridge from its packaging, and then rock the print cartridge back and forth.
4. Remove the orange cover from the print cartridge, and then pull the orange tab straight out to
remove the sealing tape.
5. Insert the cartridge into the product until it is firmly in place.
6. Close the print-cartridge door.
Nov 16, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
I need to change the cartridge on my HP LaserJet 1020, and I can't find the book detailing how to do it. All I need are the instructions................
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.Follow these steps to make sure the new print cartridge is ready to install into the product.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Dec 09, 2009 | Office Equipment & Supplies
Instructions for refill tonner
Changing the print cartridge
1. Open the print cartridge door, and remove the old print cartridge. See the recycling
CAUTION To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
2. Remove the new print cartridge from the packaging.
3. Bend the tab on the left side of the cartridge to break it loose.
4. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling.
5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the
cartridge.
6. Insert the print cartridge in the printer, making sure that the print cartridge is in position.
CAUTION If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric.
Oct 31, 2009 | HP LaserJet 1160 Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
My printer deskjet f2100 is showing a paper jam (red light showing on control panel) how do i fix it?
folow the steps below 1. Check for and remove any paper stuck in the paper in tray
2. clear the paper jam from the back of the printer
a. unplug the AIO
b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
c. gently pull the paper out fo the rollers
d. clean the rollers with a lint free cloth that is moist with distilled water
3. Lift the front cover and slowly remove any jammed paper
a. unplug the power cable
b. if necessary pull the input tray down to open it. then lower the print cartridge door
c. gently pull the paper out of the rollers
d. close the print cartridge door
e. plug the power cable
4. Verify that the print cartridge carriage can move freely
b. check to see if the print cartridge carriage can move freely from one side to the other.
c. remove the print cartridges
d. gently move the print cartridge to tyhe far right of the printer
e. remove the paper from the paper in tray, but do not remove the drawer
f. remove the rear acces door
g. with your fingers rotate the rollers "up" three full rotations
h. close the rear access door
i. replace the print cartridges
j. plug the power cable
k. turn the power on
5. reload and test the printer
hope this helps
Nov 14, 2008 | HP Office Equipment & Supplies
Paper Jam in HP Deskjet F2100 All in One
a. unplug the AIO
Aug 06, 2008 | HP Office Equipment & Supplies
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Lexmark T642 Laser Printer Logo
1,332 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
