Honeywell Thermostat RTH 7500
I had to install a new thermostat, I bought the Honeywell RTH7500, I have a multi stage heat pump. When I activate the thermostat for cool air, the fan will come on but no cool air, I can get the heat to work, but no A/C. Any suggestions?
  • Gunston May 24, 2009
    I replaced a honeywell heat pump tstat T841 to a honeywell RTH7500 w/heat pump.
    I use the 7500 wiring setting on page 22, G, Y, O, R, and White to Aux, but use a small piece of wire to connect Aux & E. The Blue wire leave alone.
    Next go to 7500 Advance setting pg 13 and follow instructions.
    I used
    function-setting
    170-7
    190-0 (because I use the O wire)
    270-5 (I have a gas furnace)
    300-1
    320-0
    330-2
    500-1 (or 2)
    530-1
    640-12
    And it works just like a pro!
  • Anonymous Mar 21, 2014
    We've tried all the buttons and changing the batteries and flipping the circuit but we can't get the heat the come on.
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
Gunston,
You the man!
I had an old Baystat 239 that would never shut off. I bought the Honeywell RTH7500, couldn't get it to cool, found your solution online and moments later I had cool temps! Thanks for the help!
Posted on Jun 07, 2010
    Problem Solver:
  • 6 Answers
The thermostat must be programmed (setup) for operation with your system. Check the manual for the settings for use with a multistage heat pump. If you are running a dual fuel system then be sure you also include this when you do your set up. In addition you must also set up the thermostat so that it will operate in the auto-change over mode.
Posted on Sep 30, 2008
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
May 10, 2009 | Heating & Cooling
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Mar 16, 2009 | Heating & Cooling
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,862 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
